Noticed throughput speed has dropped by a few Mbps and ping spikes
- Re: Noticed throughput speed has dropped by a few ...
09-07-2015 7:26 PM
We're having a few problems with pings mostly as in multiple games and game servers our ping isn't as low as it used to be 20 - 30ms now we've sitting at 50 lowest and jumping up to 300+ and back down. We've tried multiple reboots of the modem and router, changing ADSL filters, trying the test socket. Computers in the house experiencing this are both on WIFI and Ethernet and was wondering if you could take a look your end please?
Kind regards,
James.
Re: Noticed throughput speed has dropped by a few Mbps and ping spikes
11-07-2015 9:48 AM
Diagnostics are showing no issues with the connection itself.
Mind running us a speedtest http://speedtest.btwholesale.com/ whilst connected over ethernet?
11-07-2015 5:26 PM
11-07-2015 5:51 PM
12-07-2015 11:24 AM
Multiple reboots of the router wont have helped matters- system sees that as a fault and reduces the speed to compensate.
Just to check that is on adsl2+ and not fibre.
12-07-2015 12:11 PM
That's correct, hopefully that isn't the case though as this problem has been going on for 2 - 3 weeks and we've done around 5 or 6 disconnections/reboots with trying to re sync and try the tests socket ect. I've also checked the line for noise using a corded telephone through the filter and there is no cracking or hissing what so ever with the modem connected or disconnected.
12-07-2015 1:08 PM
what speed shows here https://portal.plus.net/my.html?action=data_transfer_speed.
12-07-2015 2:08 PM
12-07-2015 8:08 PM
If that works ok then start adding the other pcs see if anything is causing interference - laptop adapter? Is there a stats screen on your router that shows
the number of errors? CRCs FECs and so on Any new electrical appliances brought in to the house at the start of the problem.
13-07-2015 11:40 AM
I'm completely stumped on this end, unless the exchanged is having traffic issues I can't see if being anything in our home or the line it's self.
13-07-2015 12:34 PM
13-07-2015 12:38 PM
That's great I will keep an eye on this. Just as I was writing this we have a re sync of the connection. I will keep an eye on the connect for the next hour or so.
13-07-2015 1:14 PM
Thanks for getting that sorted!
13-07-2015 2:11 PM
