Noticed an odd login on router
- Re: Noticed an odd login on router
12-03-2014 6:43 PM
I have no idea how or what caused this so i have reset the router and changed my password and also turned the wireless off.
Anyone have any idea what caused this as it seems a bit didgy to me.
12-03-2014 6:51 PM
What router is it?
12-03-2014 6:57 PM
I diden't think to take any screenshots as i was in a rush to get things set back to normal.
Router = Technicolor TG582n FTTC
On this pic it shows my normal admin login but the other day this diagnostics setting was underneath the admin login with intercept next to it and it was ticked as the default user.
I can see an intercept option if i click on add new user but as i have never done this i have no idea how it was set to this diagnostics mode.
OK after looking again the only way i can get it to show diagnostics is to manual set a new user with Diagnostics as that name then from the drop down list i can choose intercept, I would also need to make a new password to be able to login in this mode.
12-03-2014 8:43 PM
Username : diagnostics Privileges intercept
I have change the user default back to admin but i dont see a way to remove the other login and have no clue why it's there or was logged into it in the first place, I did change the password to login to the router when i got it to one that was more easier for me to remember would that have done it, should i be worried ?
Router is Technicolor TG582n FTTC
I'm sorry i cant for the life of me figure out how to get a screen shot of it printscreen for some reason wont work
12-03-2014 9:21 PM
jim:quote
12-03-2014 9:26 PM
When your on the user manager screen click the Configure option top right of the page nex to overview, This should give you the option to remove the diagnostics user.
12-03-2014 11:37 PM
12-03-2014 11:41 PM
Quote from: Gus Is Remote Assistance enabled?
It's disabled in my router and i have not had any issues that needed any support from a remote login as i tend to fix everything myself if i can.
Still puzzled as to what caused this and looks like i'm not the only one so some info on what might have happened would be usefull.
13-03-2014 11:38 AM
13-03-2014 12:02 PM
Think i might just downgrade the firmware as i prefer the old login how it was before and to be honest i think the new firmware is slightly buged as sometimes the hole router reboots itself when i change things and it never used to do this before.
