Not very happy with This
stathe
1. Best Effort Test: -provides background information.
Download  Speed
0.46 Mbps
0 Mbps 0.5 Mbps
Max Achievable Speed
Download speed achieved during the test was - 0.46 Mbps
For your connection, the acceptable range of speeds is 0.05 Mbps-0.5 Mbps.
Additional Information:
Your DSL Connection Rate :1.63 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 0.5 Mbps
It has failed a couple of times to-day
Re: Not very happy with This
It seems there is a mismatch with your profiles, to rectify this I've placed a SNR rest on your line which should take effect  in the next 4 hours.
Let me know if this helps.
stathe
Thank you it is fine at this moment -----------Hope it stays well as I have many young relations all on line
Download  Speed
1.77 Mbps
0 Mbps 2 Mbps
Download speedachieved during the test was - 1.77 Mbps
For your connection, the acceptable range of speeds is 0.4 Mbps-2 Mbps.
Your DSL Connection Rate :2.11 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 1.75 Mbps
It should do, let us know if anything changes.
