1. Best Effort Test: -provides background information.
Download Speed
0.74 Mbps
0 Mbps 1 Mbps
Max Achievable Speed
Download speedachieved during the test was - 0.74 Mbps
For your connection, the acceptable range of speeds is 0.2 Mbps-1 Mbps.
Additional Information:
Your DSL Connection Rate :1.22 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 0.75 Mbps
Just lately my speed has deteriorated, below that which I find aceptable ( want to be able to use i player and skype ) The noise margin is 10 to 12 and it used to be around 6 or 7 Why should this be
Line Rate Max1 Max2 Max3 Mgn1 Mgn2 Attn Pwr CRCs FECs INP DLY Rate Max Mgn Attn Pwr CRCs FECs Mode Vendor State Exit Code Echo VCXO Rx Gain INC Tones
2013/10/31 14:29:34 GMT 1 1216 1244 1024 1024 9.4 9.0 69.1 15.7 559 16526 0.74 4.00 448 596 10.0 31.5 11.9
