Not recieving any outside mail since the Postini 'Update'
- Not recieving any outside mail since the Postini '...
Re: Not recieving any outside mail since the Postini 'Update'
21-01-2008 12:58 PM
Quote from: Barry I do think it's worthwhile investigating whether Postini are able to justify this behaviour. IMHO, I can't think of any offhand reason why a second pass through Postini is rejected?
Because it's very much open to abuse and the easy solution is to simply delay indefinitely or reject the message outright rather than establish if there are genuine reasons (which postini could obviously verify as being entirely correct and justifiable) why the message has been seen before.
I see it as exactly the same reason as for why postini has problems with some 100% genuine messages and routinely considers them as spam. It's simply easier not to do a thorough and accurate job
B T Plusnet, a bit kinda like P T Barnum ...
... but quite often appears to feature more clowns
21-01-2008 1:02 PM
A second pass is already "identified" by the Message ID - this is why we're getting the #451 rejections.
Ok, unusual routing may mean that it passes through twice - but what has changed? It's still the same message, and is identified as the same message so should score identically?
B.
21-01-2008 1:21 PM
As there are some good reasons why a message may be seen twice, postini should accept that fact and deal with it appropriately. I believe that means evaluating why the headers are there and either verifying that it is a totally acceptable situation or determining that it is just someone trying to be clever and looking for a possible way of circumventing the system. postini appear to be taking the easy option of just assuming that the existence of postini headers in a received message is an attempt to bypass and/or confuse the system into accepting potential spam. As I said before, I see it as exactly the same situation as not re-testing a message which was initially classified as spam to establish if it is indeed spam rather than a genuine message that just so happens to have the basic signature of some flavour of spam.
21-01-2008 1:28 PM
21-01-2008 1:42 PM
I then sent 2 test emails from my Hotmail account to work which would normally be copied to my home account.
So far nothing has arrived in my home account inbox.
I await developments as this is something I set up occasionally for people on holiday who foolishly wish to stay in touch with work.
21-01-2008 1:52 PM
Munged headers for inspection:
Quote Envelope-to: test-address@jelvs-email
Delivery-date: Mon, 21 Jan 2008 13:23:23 +0000
Received: from localhost ([127.0.0.1] helo=pih-sunmxcore13.plus.net)
by pih-sunmxcore13.plus.net with esmtp (PlusNet MXCore v2.00) id 1JGwcV-00055y-5f
for test-address@jelvs-email; Mon, 21 Jan 2008 13:23:23 +0000
Received: from exprod5mx227.postini.com ([64.18.0.86] helo=psmtp.com)
by pih-sunmxcore13.plus.net with smtp (PlusNet MXCore v2.00) id 1JGwcU-00052w-1x
for test-address@jelvs-email; Mon, 21 Jan 2008 13:23:22 +0000
Received: from source ([83.244.140.18]) by exprod5mx227.postini.com ([64.18.4.14]) with SMTP;
Mon, 21 Jan 2008 05:23:20 PST
Received: from 86.138.63.2 ([86.138.63.2]) by cieh-exch01.cieh.org ([192.168.100.31]) with Microsoft Exchange Server HTTP-DAV ;
Mon, 21 Jan 2008 13:23:08 +0000
MIME-Version: 1.0
content-class: urn:content-classes:message
Content-Type: multipart/alternative;
boundary="_BC4EB552-FBDC-4268-BFCC-E74DE6344B35_"
Subject: Test of redirect
To: "test-address@jelvs-email" <test-address@jelvs-email>
Thread-Topic: Test of redirect
Thread-Index: AchcMHWb1LP6BOxOS7izApeqhyzojA==
Message-ID: <E354975D-596C-4A7D-B47D-075C3FC741D6@mimectl>
X-Mailer: Microsoft Outlook Web Access 6.5.7651.60
X-MimeCtl: Produced By Microsoft Exchange V6.5.7651.60
Date: Mon, 21 Jan 2008 13:20:58 +0000
X-pstn-neptune: 10/9/0.90/82
X-pstn-levels: (S:81.87360/99.90000 R:95.9108 P:95.9108 M:97.0282 C:98.6951 )
X-pstn-settings: 1 (0.1500:0.1500) gt3 gt2 gt1 r p m c
X-pstn-addresses: from <jelvs-email@address> [db-null]
X-PN-VirusFiltered: by PlusNet MXCore (v4.00)
X-PN-Spam-Filtered: by PlusNet MXCore (v4.00)
So, in this case, I'm guessing that the final Exim delivery handled by pih-sunmxcore13.plus.net is "aware" of the local redirect and passes it directly to local delivery (as evidenced by the pih-sunmxcore13 -> pih-sunmxcore13 transit highlighted in bold.
Of course, if the redirect is external then the local mailer won't be aware of a local delivery option, so will route it via MX records which is what happened to TheChallenger.
mikeb: when a message is re-routed via Postini then surely Postini can:
a) Detect whether the message has genuinely passed through Postini before (via MessageId - as this is causing the #451 currently)
b) If (a) is true, then strip out any Postini headers, re-score the message, and add new headers.
B.
21-01-2008 1:57 PM
I've sent you another test to you@myhosteddomain.me.uk - has that arrived?
21-01-2008 2:03 PM
So, it seems like the Plusnet relays are definately "alias-aware" and avoid re-sending through Postini if a local delivery method is available (which is good news ;D)
The problem only occurs when MX records cause a redirect back through Postini.
I wonder if the esteemed Bob could garner some feedback from Postini about this?
B.
21-01-2008 2:05 PM
Quote from: Barry when a message is re-routed via Postini then surely Postini can: ....
Yes of course they could. After all, there is just about always a realistic and sensible solution to just about any potential problem ... it's just that it's most often so much easier not to find one but to make wild and unfounded assumptions and act on them instead !
Similarly, they could re-test messages that have been initially classified as spam to establish if they are actually totally genuine messages ... but they don't appear to. Looking at some (most) of the false positives that have been highlighted by users various, I think it's pretty easy to come up with a fairly generic test to confirm with a reasonably high level of confidence that whilst they may well have the basic signature of some flavour of spam they are in fact totally genuine.
Edited to add: I'm pretty sure that I saw more than a few complaints about both these problems when I was researching postini ages ago but I can't find examples to post at the mo. I got the distinct impression that 'going round the loop twice' and false positive issues were a sad fact of life and that postini have made no real attempt to address either problem over a lengthy period of time.
21-01-2008 2:06 PM
I can't imagine there will be many people in a situation similar to TheChallenger's however this has been noted for investigation nonetheless.
21-01-2008 2:06 PM
Quote from: Bob this has been noted for investigation nonetheless.
That makes me feel wanted
21-01-2008 2:14 PM
B.
21-01-2008 2:15 PM
Edit: But if I forward to my Hotmail account.......
21-01-2008 2:25 PM
21-01-2008 2:33 PM
It actually depends on your Exchange server which will be attempting to deliver to Postini on your behalf.
Certainly, the PN relays gave me a 4h, then a 24h, and 48h "reminder" saying they were attempting to redeliver.
I finally got an NDR 96 hours after initial delivery attempt.
B.
