Not really a new topic - Peak Time slowdown still happening.
- Not really a new topic - Peak Time slowdown still ...
Re: Not really a new topic - Peak Time slowdown still happening.
23-04-2013 12:19 PM
23-04-2013 6:42 PM
1. Best Effort Test:
Download Speed : 8.28 Mbps
2. Upstream Test:
Upload Speed : 0.9 Mbps
Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information.
You are currently connected to gateway pcl-ag05.
This is located in City Lifeline House.
23-04-2013 7:53 PM
1. Best Effort Test: -provides background information.
Download Speed
4.05 Mbps
0 Mbps 21 Mbps
Max Achievable Speed
Download speed achieved during the test was - 4.05 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 15.1 Mbps
Upload Speed
0.89 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.89Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
Still on pcl-ag05.
24-04-2013 12:13 AM
24-04-2013 10:14 AM
27-04-2013 4:08 PM
Anyway, it does still seem to be persisting - slow speeds between (around) 6pm till exactly midnight. This afternoon is also now exhibiting similar problems.
Its getting to be very annoying and id really like to know is it a exchange/network or traffic shaping issue so I can decide how to best go about getting the service improved.
I made a support ticket earlier on - 68887133.
27-04-2013 6:21 PM
Which gateway
You are currently connected to gateway pcl-ag06.
I'll be off to work in about 30 minutes so won't be able to test again tonight. There's an engineer appointment booked for Friday afternoon, but I suspect he won't find anything wrong. I'll keep my fingers crossed...
29-04-2013 1:38 PM
@MrK
We'll test your line and go from there.
02-05-2013 3:21 PM
(removed) - CSC Analyst
9:42am, Thursday 25 Apr 2013
Dear Mr H,
Thanks for getting in touch with regards to the fault with your service, I'm sorry to see that there are currently some issues. As per the message I've left on your mobile, we cannot see a Hot VP reported by BT Wholesale on anything we have access too at this time. However we can see that you're getting low throughput on the TAP3 in peak times, which suggests there is an issue somewhere on the BT Network.
I can see that you've not asked for an engineer at this time, however this would be our next step to progress your fault. We'd be asking him to co-op with the Triage Team which may result in a second appointment for an engineer to come during the peak period. We'd also be asking for you to be moved onto different equipment, and onto a different VP, to see if this resolved your issue."
Download Speed
12.7 Mbps
0 Mbps 21 Mbps
Download speedachieved during the test was - 12.7 Mbps
IP Profile for your line is - 13.09 Mbps
Upload Speed
0.43 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.43Mbps
ADSL Line Status
Connection Information
Line state: Connected
Connection time: 0 days, 00:23:18
Downstream: 14.49 Mbps
Upstream: 1.119 Mbps
ADSL Settings
VPI/VCI: 0/38
Type: PPPoA
Modulation: Unknown or no mode configured
Latency type: Interleaved
Noise margin (Down/Up): 6.3 dB / 6.5 dB
Line attenuation (Down/Up): 24.5 dB / 12.4 dB
Output power (Down/Up): 20.4 dBm / 12.5 dBm
FEC Events (Down/Up): 5927249 / 0
CRC Events (Down/Up): 2319 / 32
HEC Events (Down/Up): 18933 / 7
Error Seconds (Local/Remote): 33175 / 170
Interesting - the upload speed has dropped considerably, and the downstream SNR has gone to a 6dB target - it's been stable at 3dB for as long as I can remember, so I've lost about 2Mb from my downstream synch speed, presumably as a result of the engineer's testing. The upstream synch hasn't changed.
I'll do a couple of tests at peak time tonight.
02-05-2013 3:59 PM
This is more like it:
Download Speed
12.76 Mbps
0 Mbps 21 Mbps
Download speedachieved during the test was - 12.76 Mbps
Upload Speed
0.88 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.88Mbps
02-05-2013 4:09 PM
02-05-2013 6:03 PM
ADSL Line Status
Connection time: 0 days, 00:19:16
Downstream: 16.63 Mbps
Upstream: 1.13 Mbps
ADSL Settings
VPI/VCI: 0/38
Type: PPPoA
Modulation: G.992.5 Annex A
Noise margin (Down/Up): 3.0 dB / 6.1 dB
Line attenuation (Down/Up): 24.2 dB / 12.2 dB
Output power (Down/Up): 20.3 dBm / 12.4 dBm
FEC Events (Down/Up): 50718 / 89
CRC Events (Down/Up): 30 / 41
HEC Events (Down/Up): 2125 / 190
Error Seconds (Local/Remote): 33260 / 173
Speeds still looking good, just before 6pm.
Download Speed
14.14 Mbps
0 Mbps 21 Mbps
Download speedachieved during the test was - 14.14 Mbps
IP Profile for your line is - 15.02 Mbps
Upload Speed
0.9 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.9Mbps
I'll check back in about 30 minutes.
[edit - typo]
02-05-2013 6:30 PM
02-05-2013 6:57 PM
02-05-2013 7:43 PM
