Not looking good
jld51
Not looking good
1. Best Effort Test:  -provides background information.
Download Speed
38.73 Mbps
0 Mbps 77.44 Mbps
Max Achievable Speed
Download speedachieved during the test was - 38.73 Mbps
For your connection, the acceptable range of speedsis 40 Mbps-77.44 Mbps .
Additional Information:
IP Profile for your line is - 77.44 Mbps
2. Upstream Test:  -provides background information.
Upload Speed
14.68 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 14.68Mbps
Re: Not looking good
Are you testing via the wireless or with a wired ethernet cable ?
jld51
with a wired Ethernet cable ?
That's that theory out then - quite often when using the wireless you get a much slower rate.
I am assuming Plusnet have set you on the wrong speed profile their end. What does it say for Current Line Speed here https://portal.plus.net/my.html?action=data_transfer_speed ?
jld51
Phone exchange:
NUNEATON
Estimated line speed:
72Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2014-03-04 21:12:43
Current line speed:
78 Mb
Ok, so it's not an issue with your Plusnet profile.
Nuneaton exchange has had reported peak time speed problems. Are you seeing the slow downs at specific times or all the time?
jld51
My speed does not drop at all stays the same all the time.
vicky1959
had same problem  exact same speeds turned out profile @PN was set wrong,mod here noticed  sent ticket speed upped to correct speeds
Plusnet Alumni (retired) LinnPlusnet
Hi jld51,
Are you able to run the BTW speed tester and post your results?
This can be found here: http://speedtest.btwholesale.com/
I've had a look for you and your connection profile is set correctly on our side. I'll run some tests and see if anything stands out, jld51. I'll update any findings shortly.
jld51,
Can you run the BTW speed tester again and perform a TAP3 test? There should be a step-by-step guide explaining how you do this when you run the BTW speed tester.
