Not impressed
- Not impressed
Not impressed
14-10-2007 5:32 PM
Re: Not impressed
14-10-2007 5:43 PM
It could be anything and could even be down to the fact there's been some rain over the weekend. What sort of sync speeds are you seeing currently? Are they back to wehat you usually get? If so, your speed profile should bounce back to what it used to be.
Re: Not impressed
14-10-2007 7:48 PM
and weather here's been gorgeous, no rain since early in the week...
Quote ADSL Link Downstream Upstream
Connection Speed 4416 kbps 448 kbps
Line Attenuation 31.0 db 18.0 db
Noise Margin 9.3 db 21.0 db
Quote Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 3000 kbps
DSL connection rate: 448 kbps(UP-STREAM) 4416 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 2697 kbps
If you wish to discuss these results please contact your ISP.
If you are experiencing problems with specific applications, servers or websites please contact your ISP for assistance.
Your test has completed please close this window to exit the performance tester.
Re: Not impressed
15-10-2007 7:43 AM
Connection Speed 4896 kbps 448 kbps
Noise Margin 9.4 db 21.0 db
Yes connected to master socket ...
As for dialling that number. there is no audible noise, completely quiet.
Re: Not impressed
15-10-2007 8:24 AM
Looking at BTs logs, your sync speeds have deteriorated since August 6th. According to them they haven't seen any synchronisation speeds in the region of 6000Kbps since then. At least they haven't seen any that would cause your profile to increase. There's been various decreases since then, with the last from last night being 3424Kbps.
I'd recommend trying from the test socket and also ensuring that you have tried using different filters.
Re: Not impressed
15-10-2007 9:17 AM
how do i try the test socket?
Re: Not impressed
15-10-2007 9:31 AM
If you unscrew the face plate form your master socket, there is another socket in there on the bottom right. This is called the test socket.
If you maintain your current connection speed, your profile should be increased to 4000Kbps within the next 3 days.
Re: Not impressed
15-10-2007 9:37 AM
Re: Not impressed
15-10-2007 9:38 AM
You should be able to see from the BT Speedtester which profile you are on, depending on whether or not you can get it to work.
Re: Not impressed
15-10-2007 9:40 AM
Jules
x
Re: Not impressed
15-10-2007 9:42 AM
If you want me to, just give me a prod and I'll be able to see if any BT profile changes have been made.
Re: Not impressed
15-10-2007 9:50 AM
Connection Speed 7616 kbps 448 kbps
Line Attenuation 30.0 db 18.0 db
Noise Margin 9.4 db 23.0 db
Shame it's not like that normally, why the dramatic change?
Re: Not impressed
15-10-2007 9:53 AM
I've had as high as 7500Kbps (with my downstream attenuation of 45dB!) but reboots can give anything from 5.5-7.5Mbps. It is however a fairly dramatic change. I'd avoid rebooting your router for awhile if I were you
Re: Not impressed
15-10-2007 9:58 AM
Re: Not impressed
15-10-2007 10:05 AM
It's up to you. If you can live with the faceplate being removed, then go for it. Unless you're talking about some fairly hefty amounts of gunk getting in there, then I'd leave it that way. I'd definitely also recommend trying to see if you can get those kind of sync speeds with the faceplate attached.
