Not happy paying for this months broadband!
LJEDM
There was an outage not too long ago that lasted a few days, that was apparently sorted. But since then there have been many outages, some short, some lasting a day or longer. Also when the broadband has been connected it has been half the speed that it was prior to these issues.
Plusnet Staff
Plusnet Staff
Fixes: 159
Re: Not happy paying for this months broadband!
If you've seen outages after the ones we posted to our service status, I'd advise getting a fault reported to us so we can investigate what's happening https://faults.plus.net
 Chris Parr
 Plusnet Staff
LJEDM
The outages don't seem to be in relation with the service status outages. The broadband is back up, but still at half the speed it was prior. Fibre has just become available in the area and we are questioning whether this is PlusNet/BT's way of pushing us towards the more expensive packages.
Plusnet Staff
Plusnet Staff
Fixes: 159
Have you reported the issue using the link above to us?
We cannot directly control the sync or sync speeds between your premises and the exchange, if there is a fault causing the issues we need to look in to this.
 Chris Parr
 Plusnet Staff
LJEDM
I have done. I received a text when the broadband came back up stating that the problem has been resolved. I can;t say the issue with speed is anywhere near resolved.
Plusnet Staff
Plusnet Staff
Fixes: 159
Please send me a private message and I'll take a look.
 Chris Parr
 Plusnet Staff
Plusnet Staff
Plusnet Staff
Fixes: 159
Thanks, I'm testing your line and there's nothing obviously wrong. It's quite a long line though so the performance isn't going to be great if I'm honest on ADSL.
Downstream Link Info
Loop Loss Loop Loss Add Text SNR Margin Errored Seconds HecErrors Cell Count Speed
61   6 0 0 1283337032 1344
The line is slightly below what's known as the FTR (Fault Threshold Rate) so we can try and push this through as a speed issue, even though you are well within the estimates for your line.
Before we do this, how is your router connected? Are you in the test socket without using any extension leads?
Estimates
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
  High Low High Low
VDSL Range A (Clean) 45.2 34.3 8.1 5.8 -- Available -- --
VDSL Range B (Impacted) 37 21.3 7.3 3.7 -- Available -- --
ADSL Products
Availability Date
Left in Jumper
ADSL Max Up to 1 -- 0.75 to 2.5 Available -- --
 Chris Parr
 Plusnet Staff
LJEDM
Thank you. Yes the router is directly plugged into the test socket with no adapters.
Plusnet Staff
Plusnet Staff
Fixes: 159
The testing I'm doing might force your line to disconnect briefly too.
 Chris Parr
 Plusnet Staff
LJEDM
That's fine
Plusnet Staff
Plusnet Staff
Fixes: 159
OK, the next step is an engineer booking. I've updated the ticket on your account with details and you can reply to that here: https://www.plus.net/wizard/?p=view_question&id=130631625
 Chris Parr
 Plusnet Staff
Plusnet Staff
Plusnet Staff
Fixes: 159
It is worth keeping in mind that any increase in speeds you might see will be marginal simply due to the length of the line.
 Chris Parr
 Plusnet Staff
