Not getting new speed yet... Should I give it a while?
- Not getting new speed yet... Should I give it a w...
29-10-2012 10:27 AM
I upgraded to the newer version of the Fibre Extra package for this billing cycle. I've had an email telling me I've been successfully moved over, but my download speed is still the same.
I've reboot the router and the BT OR box plugged into the socket but no difference.
I'm expecting 60ish but am still getting the pre-change speed:
The page at https://portal.plus.net/my.html?action=data_transfer_speed tells me that my current line speed is 78 Mb.
I've no idea what my sync speed it as this awful router (the plusnet WNR1000v3 netgear box from the fibre trial) doesn't seem to be able to tell me (unless I'm being a tool and it's right in front of my face) 😕
Should I just wait for a while or does it need a manual kick somewhere?
-JT
-JT
Message 1 of 5
(1,022 Views)
4 REPLIES 4
Re: Not getting new speed yet... Should I give it a while?
29-10-2012 10:45 AM
It's nothing to do with the router. Only the BT OR modem knows what the synch speed is and it wont allow you to see it with the standard BT firmware.
Quote 've no idea what my sync speed it as this awful router (the plusnet WNR1000v3 netgear box from the fibre trial) doesn't seem to be able to tell me (unless I'm being a tool and it's right in front of my face) 😕
A BT speedtest will show you the IP Profile which is calculated directly from the synch speed. IIRC its about 88% of the synch speed.
Message 2 of 5
(487 Views)
29-10-2012 10:56 AM
Good call.
My profile still isn't updated
Not sure why the speed ranges are 0 though.
Message 3 of 5
(487 Views)
29-10-2012 1:58 PM
I expect your product details in the Member Centre have been updated but the order on BT to transfer you to the 80/20 service has still to complete. Are there any closed service notices on your account related to this?
David
Message 4 of 5
(487 Views)
29-10-2012 2:48 PM
Hi JT,
The modify order that has been placed to move you onto the new product has not completed, it is scheduled to complete today and usually has completed by this time, by the end of the day you should your increase in speed.
Apologies for the delay.
Let me know how you get on.
Chris
Chris
Message 5 of 5
(487 Views)
