Not able to display web pages seemingly randomly
Pete4000uk
For several weeks now I constantly find that some sights randomly fall of the internet. For example, I can go to Google and type in a search, but instead of the results page the ‘page cannot be displayed’ error message comes up. If I then try to go back to Google it wont load. I can get that for any number of web sites at random but after I leave it for a while everything seems to correct itself. At first I thought it was perhaps my antivirus or something but that’s not the case.
It might be something my side, I did end up with 600kbps upload speed and 440kbps download speed the other day, so..?
mikeyd
Re: Not able to display web pages seemingly randomly
If it was just the last few days then I would have guessed you were suffering from the current plusnet DNS problems.  See http://community.plus.net/forum/index.php/topic,77567.0.html
Fixes: 70
As mikeyd has alluded to, sounds like you're suffering from the intermittent DNS/routing problems that we're investigating. Probably worth you keeping an eye on Service Status.
We're trying our hardest to get to the bottom of things.
Plusnet Products Team
Pete4000uk
Ahh, I did wonder if it was somthing like that. As long as I know its not my end and that its all in hand thats the main thing!
Wink  Smiley
scarrabri
Quote from: Pete4000uk
Hi i have the very same problem ,so i think the problem is at plusnets end ,best wishes Brian
Fixes: 70
The intermittent web browsing problems should now be fixed. @scarrabri, have you been having problems this evening? I notice that your kit's disconnected a few times over recent days, is this intentional?
Session Started	Session Ended	Session Duration
18:03 09/Jul/2009 N/A   2:15:43 (on going)
11:18 09/Jul/2009 16:59 09/Jul/2009   5:40:17
09:02 09/Jul/2009 10:04 09/Jul/2009   1:2:3
06:36 09/Jul/2009 06:54 09/Jul/2009   0:18:1
22:08 08/Jul/2009 22:48 08/Jul/2009   0:40:2
19:58 08/Jul/2009 20:42 08/Jul/2009   0:44:8
08:38 08/Jul/2009 14:02 08/Jul/2009   5:24:16
06:21 08/Jul/2009 07:37 08/Jul/2009   1:16:4
21:09 07/Jul/2009 00:07 08/Jul/2009   2:58:9
17:58 07/Jul/2009 19:56 07/Jul/2009   1:58:6
05:58 07/Jul/2009 15:35 07/Jul/2009   9:36:29
20:43 06/Jul/2009 23:47 06/Jul/2009   3:4:9
