Nonexistent upload speed
wendyh
I am having really bad upload speeds, barely hitting 0.2Mbps and sometimes not even that. Hopefully this is not how it is supposed to be and someone can help me out?
Thank you
6 REPLIES 6
Manny7860
Re: Nonexistent upload speed
Adsl or fibre. What was you getting before?
Excellent!
wendyh
ADSL. I have only started taking note of the slow upload speed as of late because of a new job. What is the normal upload speed for ADSL?
Thank you
Manny7860
Upto 1meg i believe. When I was on adsl I use to hit 1 meg sometimes half that or lower. Sometimes use to hit 1.45mb
Excellent!
wendyh
Well the highest I have ever had that I can remember was 0.5Mbps, and even that seems rare these days. Is there anything I can do from home to change this or do I need help from plusnet support?
Thank you
Manny7860
Maybe pn support could uncap it.
Excellent!
Fixes: 1,600
Welcome to the community forums @wendyh
Our tests are showing your router in sync at an upstream speed of 339kbps which seems a bit low. Testing your line is showing a potential line fault so I'm raising that to Openreach now and I'll update you via your account soon.
