Non-existent upload speeds over the past few days
Dodge9876
Hi guys,
Been happy with my Plusnet service for a couple of years now, but for the last few days my internet connectivity has been sketchy.  Speed tests show download speeds as normal (4-5 Mbps) but upload speeds are practically non-existent (0.04 Mbps)
I've changed the ADSL filter (no change), I don't have another router to try at the moment but in the mean time I thought I'd ask if anyone has any suggestions?
Cheers.
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Non-existent upload speeds over the past few days
Hi Dodge9876,
Are you connected via an Ethernet Cable or Wireless? If it's Wireless, could you please connect an Ethernet Cable and let us know if there is any difference?
Chris Pettitt
Cloud Environments Engineer
Dodge9876
Hi Chris,
Thanks for the reply.  It's the same whether connected by ethernet or wireless.
Cheers.
Plusnet Staff
Plusnet Staff
Fixes: 5
I've just reset your line, if you could give it a few minutes and let us know if there's any difference?
Chris Pettitt
Dodge9876
No different I'm afraid Chris - still 4.6 download and now not even registering on http://www.speedtest.net/ for the upload speed.  It took me ~30 seconds to submit my last post!
I've power cycled my router too.
Plusnet Staff
Plusnet Staff
Fixes: 5
Thanks for trying.
Can you please raise a fault with us at http://faults.plus.net and we'll have our Faults Team take a look for you.
Chris Pettitt
