Non-existent upload speeds over the past few days
- Re: Non-existent upload speeds over the past few d...
18-07-2014 9:42 AM
Hi guys,
Been happy with my Plusnet service for a couple of years now, but for the last few days my internet connectivity has been sketchy. Speed tests show download speeds as normal (4-5 Mbps) but upload speeds are practically non-existent (0.04 Mbps)
I've changed the ADSL filter (no change), I don't have another router to try at the moment but in the mean time I thought I'd ask if anyone has any suggestions?
Cheers.
Cheers.
Message 1 of 6
(772 Views)
5 REPLIES 5
Re: Non-existent upload speeds over the past few days
18-07-2014 9:57 AM
Hi Dodge9876,
Are you connected via an Ethernet Cable or Wireless? If it's Wireless, could you please connect an Ethernet Cable and let us know if there is any difference?
Message 2 of 6
(554 Views)
18-07-2014 9:58 AM
Hi Chris,
Thanks for the reply. It's the same whether connected by ethernet or wireless.
Cheers.
Cheers.
Message 3 of 6
(554 Views)
18-07-2014 10:04 AM
I've just reset your line, if you could give it a few minutes and let us know if there's any difference?
Message 4 of 6
(554 Views)
18-07-2014 11:15 AM
No different I'm afraid Chris - still 4.6 download and now not even registering on http://www.speedtest.net/ for the upload speed. It took me ~30 seconds to submit my last post!
I've power cycled my router too.
Message 5 of 6
(554 Views)
18-07-2014 11:32 AM
Thanks for trying.
Can you please raise a fault with us at http://faults.plus.net and we'll have our Faults Team take a look for you.
Message 6 of 6
(554 Views)
