Non- Secure connection warning message
- Non- Secure connection warning message
27-08-2018 7:32 AM
I can no longer connect to my account at Welsh Water and I get the 'no secure connection' message. This is the same on all my devices so must be a plusnet issue. I have tred to understand the messages on the forum abut this but can't grasp how to fix this issue. Any advice for ths IT simpleton?
Re: Non- Secure connection warning message
27-08-2018 8:34 AM
27-08-2018 8:54 AM
Thanks. Other people have no problem accessing the site using a different broadband provider so this made me think it might be a plusnet issue rather than welsh water.
27-08-2018 9:02 AM - edited 27-08-2018 9:28 AM
Hello,
If you have a saved bookmark delete it and try https://www.dwrcymru.com
More info, it is the connection the browser is making to Welsh Water not the internet connection reporting the error.
Dan
27-08-2018 9:29 AM
Have you tried a different browser? I use Firefox with the HTTPS Everywhere extension. Failing that I agree it's probably a missing or incorrect certificate.
27-08-2018 10:02 AM - edited 27-08-2018 10:11 AM
If you can post a screenshot of what you're seeing it will help. Just remove any personal information.
What device are you using?
I'll check the site now and see if it is a server based issue.
EDIT: Using my Mac the certificate comes up as expiring as the 8th April 2020. So it looks fine from their end.
27-08-2018 12:44 PM
Hi @keith2904
Sorry to hear you are unable to gain access to Welsh Water.
Before going through any intrusive testing, I would recommend ensuring the time and date are correct but I appreciate this is very likely to be the case.
After the above, we require information which @Alex has stated. If possible in the meantime, test the website on another device.
Thank you.
