Noisy phone line when router connected
- Noisy phone line when router connected
28-07-2014 2:44 PM
I have no other equipment connected to the phone line.
Can anyone suggest a course of action.
Re: Noisy phone line when router connected
28-07-2014 2:50 PM
I've just carried out some testing on your line I've not been able to spot anything remotely. Does the crackling only start once the router is powered up or is it still there when there's just a phone connected?
28-07-2014 2:55 PM
The noise on the line does not start when the router is powered up but when it is connecting to the DSL line and with the DSL line flashing. (Sorry if I wasn't clear on this)
28-07-2014 2:58 PM
28-07-2014 2:59 PM
Is the phone DECT or wired?
Is the phone using the same socket / filter as the router? If separate, both phone and router must be plugged into filters.
Are the two (or more) filters identical? Have they both been used previously? Note they could both / all be defective.
I sometimes can hear very faint modem noises on the phone line, but not something matching what you describe.
28-07-2014 3:02 PM
I have tried both a DECT phone and a wired phone into the main socket with the same result.
Phone and router are both plugged into the same filter/socket.
I have substituted a new Belkin filter for 2 other unbranded filters with the same result
28-07-2014 3:04 PM
28-07-2014 3:14 PM
28-07-2014 3:17 PM
Out of curiosity, I have just tried a broadband speed test and found it to be very slow, <1Mb. I used to get close to 6Mb. Is this related?
28-07-2014 3:21 PM
28-07-2014 11:15 PM
29-07-2014 7:51 AM
29-07-2014 10:50 AM
I had already tried a different RJ11 cable.
I bought a new Belkin filter to replace the unbranded one.
I have also double filtered the phone.
None of these actions has had any effect.
Do you think that the router disconnection(s) and slow broadband simply coincidental?
29-07-2014 11:19 AM
Can you please gather the information requested in the speed issues thread at the top of the broadband forum?
29-07-2014 11:47 AM
1. Router Stats
D/s U/s
Noise Margin 30.3dB 22.9dB
Speed 1151Kpbs 443Kpbs
Attenuation 40.0dB 20.5dB
2. BT Speedtest
Download 0.79Mbps Acceptable range 0.4 - 1
IP Profile 1.01Mbps
Upload 0.24Mbps Upstream rate IP Profile 0.45Mbps
3. Current Line Speed 1Mb
