Noisy Router Investigation
- Noisy Router Investigation
Re: Noisy Router Investigation
17-10-2013 1:26 PM
19-10-2013 10:42 PM
Back in June, Matt indicated that the next batch of routers would include a fix for this problem. Can you tell us when will they be available?
Quote from: Matt We’ve identified a solution which is to introduce a capacitor to remove the 4Khz harmonic without any negative effects (this component is normally present in TG582n devices with the USB port).
The routers with USB ports are not affected because they already contain this extra component which stops this noise, this component is part of the dying gasp circuitry which is not present in the non-USB version. We’ll be making a change in our next manufacturing run which is scheduled for the end of June, these take a while to come from China so will begin shipping to customers later in the year.
21-10-2013 12:51 PM
I presume your new router doesn't have a USB port? Let me know and I'll chase this up.
21-10-2013 6:37 PM
You are correct, this one doesn't have a USB port.
The silent USB one that you supplied from this thread unfortunately stopped working.
22-10-2013 10:03 AM
I'll arrange to get another shipped out for you.
22-10-2013 10:20 AM
On two occasions in a week it literally stopped working. The Wifi signal disappeared and all the lights were off. The top of the router was still warm though. Power cycled and it was still dead. It would only power up if left unplugged for a few hours. I still have it if you want it back.
22-10-2013 10:57 AM
02-12-2013 8:36 PM
A few weeks ago I received a new TG582n router (without USB port) and can confirm it has the annoying high pitched whine. Would it possible to explore getting this rectified?
Mathew
02-12-2013 9:00 PM
Its silent replacement with USB port died and its replacement is now whistling.
Are the new black Thomson routers available yet for replacements?
03-12-2013 2:26 AM
Had my service activated with Plusnet (business broadband unlimited) couple of months ago. My TG582n router (without the USB port) has the annoying high pitched whistle. Would it be possible to get a replacement router please?
Many thanks,
03-12-2013 8:54 AM
03-12-2013 9:14 AM
03-12-2013 9:25 AM
03-12-2013 9:27 AM
03-12-2013 9:36 AM
