Noisy Router Investigation
- Noisy Router Investigation
Re: Noisy Router Investigation
10-05-2013 10:56 AM
10-05-2013 11:54 AM
11-05-2013 12:11 PM
Forgot about this thread and just caught the postman today with a new router.
This one has the USB port (I assume for hosting files over the network). Does this mean I can't use the 10.? Demo firmware on my ADSL connection?
11-05-2013 12:35 PM
11-05-2013 12:38 PM
Will try it shortly however it's already annoying me as its missing a rubber foot so won't sit still 😞
11-05-2013 12:42 PM
Not sure why as no one was online. Hmmm...my SNR has dropped to 4.6dB too.
Will try the new router after manually disconnecting.
11-05-2013 12:48 PM
Quote from: Damian78 Will try it shortly however it's already annoying me as its missing a rubber foot so won't sit still 😞
It seems that only some people are able to discern small movement due to a missing rubber foot. There have been one or two reports from other customers. Do you think you could record this missing foot?
11-05-2013 1:51 PM
New router is now silent and removed a rubber foot off the old router. It's on firmware revision 8.4.4.J I think.
Will there be a revision for the USB enabled routers soon? It seemed to improve my Wifi connection when I upgraded the noisy one.
11-05-2013 2:12 PM
11-05-2013 2:27 PM
Does the FTTC firmware work ok on ADSL?
11-05-2013 2:31 PM
11-05-2013 2:39 PM
Quote from: chrispurvey @andy265
I'm going to arrange deliver of a new router for you
Got it today, thanks!
New router makes no noise at all. I'll get the old one on its way back to you Monday.
11-05-2013 2:43 PM
11-05-2013 2:53 PM
Quote from: chrispurvey If you could send the router and power supply in the returns bag
I got two returns bags, a Plusnet one in the bag with the new router, and a BT one posted separately. I assume it's the Plusnet one I'm sending it back in?
11-05-2013 3:27 PM
As it seems you transferred from BT Broadband, I guess the BT one is for your HomeHub, but you'll need to check your BT Ts&Cs they could well be entitled to it back. The Plusnet one would be for the PN modem/router, someone from the DCT could no doubt confirm that on Monday if you have any doubts.
@Damian78
Depends what you meant by what's the difference with the Routers. Initial ADSL modem/routers sent out had a USB port, later ones did not. AFAIK it's some of these later ones that had the noise problem. All the Fibre Router ones all had/have a USB port AFAIK and are flashed with different firmware that turns a LAN port to a WAN for Fibre, so you only have 3 LAN ports on Fibre.
The latest DEMO firmware appears to support both modes and USB on Fibre but waiting for confirmation of USB support in ADSL mode - it should do, but it would be wise to see what reports comeback from initial tests. As you might have a line issue it would be wise to wait a while and see how the new router pans out before changing any firmware..
