Noise Margin jumped up to 15dB today (Exchange enabled for 21CN)
- Noise Margin jumped up to 15dB today (Exchange ena...
30-04-2008 10:00 AM
"BT Wholesale has set an enablement date of 30/04/2008 for their 21CN Wholesale Broadband Connect product at the Dunfermline exchange"
Can I get PlusNet to get BT to sort this ?
Re: Noise Margin jumped up to 15dB today (Exchange enabled for 21CN)
30-04-2008 1:46 PM
30-04-2008 2:21 PM
I have raised a ticket to get PN to ask BT to lower my Noise Margin.
cp:quote
30-04-2008 3:05 PM
So it will just be a coincidence that your connection has changed or some BT engineer pressing the wrong buttons.
You will need to raise a speed fault but specify you want the target noise margin reduced.
01-05-2008 11:18 AM
18-06-2008 8:16 AM
I've been wondering why our noise margin had gone up from its usual 5db or so to nearer 15db, with a resultant drop in speed but as we have a guest staying for a couple of weeks, I didn't want to be messing around testing the connection till she's gone. Also, we're now often being connected with the mysterious 15.5db line attenuation that sometimes occurs, instead of our usual 30db or thereabouts.
After reading this, I think I'll just wait and see what happens and only raise a ticket if it's not back to normal when they've finished what they're dong at the exchange!
Full Fibre since September 2023
Mac OS14 and Firefox user with latest versions of both
18-06-2008 3:37 PM
Eventually got good sync(7700Kbps), good noise margin, even got PlusNet to give me a good profile (6500Kbps)
BT speedtester showed the same.
However, PN speedtester showed 1400Kbps any time of the day or night,
This was in accordance with general speed of websites.
Raised tickets with PN.
Eventually got back at a decent data rate (3-5Mbps in the afternoon).
My exchange boasts to be going 21CN in the next couple of weeks
20-06-2008 9:07 PM
My broadband is more reliable the HIGHER the noise margin. eg. 5dB would be virtually unusable, 12db ok, but 18db excellent. Noise margin is the DIFFERENCE between wanted signal and noise. The higher the margin the better.
I suspect the drop in speed is only temporary?
In ANY communications system, engineers strive to achieve the highest signal/noise ratio (noise margin)that is possible.
Robin
20-06-2008 9:19 PM
The whole point of the system is to give you the highest stable speed possible not the highest noise margin.
20-06-2008 9:40 PM
Quote from: francoise Am I missing something here?
Robin
Yes: Noise margin is different to signal/noise ratio.
Noise margin is - roughly "minimum allowed S/N ratio"
The more you hold in reserve, the slower the line (and up to a point) the more stable the line.
So your speed reduction is permanent, unless you do something about it.
Choose a value (6dB is mostly OK) and 18dB ludicrous that allows a few occasional errors.
20-06-2008 9:54 PM
That explains all. BTW, I am on a fixed 2M, s/n is usually around 22db. If it dropped to say 10db, i may get problems. This is what i was (incorrectly) basing my comparison on. I always strive for best s/n.
Well, I learnt something today!
OP, good luck with your request!
Robin
20-06-2008 11:09 PM
Robin
Our noise margin has only recently increased to approx 15db from 5db and suddenly, for no apparent reason. It was fine before, with no disconnections or anything after problems last year that were fixed by a BT chappie cleaning out the connection box at the top of the telephone pole. The line doesn't seem to have developed noise again, which it had with the previous problem.
As I said earlier, I discovered our exchange's switch to 21CN is imminent and then saw here that someone else had a similar sudden increase in noise margin in similar circumstances, so wondered if the two were connected.
20-06-2008 11:30 PM
Quote from: Mad As I said earlier, I discovered our exchange's switch to 21CN is imminent and then saw here that someone else had a similar sudden increase in noise margin in similar circumstances, so wondered if the two were connected.
Yes - I feel sure that this was the cause of a recent speed dropfor me. However, a ticket to PlusNet has fixed it.
It doesn't seem possible to make a major change and not have it affect broadband in a bad way.
See attached (the green bar shows my noise-margin reaching about 20dB).
[Monitored every 5 minutes]
01-07-2008 12:27 PM
Plusnet has asked BT to reduce it twice successfully but the failed the 3rd time. From my perspective at 6db the line was fast and stable, BT reckon that it was fast and unstable so increase the margin. Now line is just slow. I'd accept this if not for the fact it ran at 6db for the past 2 years with no problem.
I wonder if BT has some new algorithm to calculate the Target noise margin which is less forgiving than it use to be.
01-07-2008 12:33 PM
