No web browser
- No web browser
No web browser
19-10-2009 2:33 PM
Sorry if I have posted this in the wrong section. My broadband was activated today but I can’t get any web browsers to open on my pc. I can access windows messenger no problem, but when I try and open my emails or search online all I get is a page saying internet explorer cannot open this page. I have been on to plusnet but they have no idea what the problem could be.
I am using my laptop at the moment and all is fine on that and also my son’s pc is running great, its just mine. Anyone know what the problem could be?
Re: No web browser
19-10-2009 2:37 PM
If you go to your control panel, select internet options, hit the connection tab, what does that page show?
What does it show if you click the LAN settings box?
That's assuming you're using Windwos XP or before....
Re: No web browser
19-10-2009 2:43 PM
Thanks for replying.
When I got to control panel and select internet option and so on the page shows nothing at all. And when I click the LAN settings box the automatically detect settings is ticked.
I am using windows XP.
Re: No web browser
19-10-2009 2:49 PM
Has the call centre talked you through specifying your DNS servers too? (If that bit doesn't help).
Is your computer wired to the router or is it wireless?
Re: No web browser
19-10-2009 3:12 PM
The computer is wired to the router, as mentioned in my first post messenger works fine it just the loading on web pages.
It seems that it is a http problem, as if I diagnose the problem I get this message.
Quote Windows cannot connect to the internet using http, https or ftp this is probably caused by fire wall setting on this computer.
Check the firewall setting for the http port 80, https port 443 ftp port 21
You might need to contact your isp.
I have turned off windows firewall and I’m still getting the same problem, I never had any of these issues with my other internet provider
Re: No web browser
19-10-2009 3:22 PM
Re: No web browser
19-10-2009 3:46 PM
Re: No web browser
19-10-2009 5:01 PM
Re: No web browser
19-10-2009 5:03 PM
I'm afraid I can't think of a reason why IE wouldn't load, but messenger would, as messenger will use the same settings for its connection.
Re: No web browser
19-10-2009 5:06 PM
Re: No web browser
19-10-2009 5:07 PM
Re: No web browser
19-10-2009 5:23 PM
This solution worked in several cases
Quote Hi,
first check if your ip and your DNS are automatically obtained... do the following
I had the same EXACT problem and this resolved my issue right away.
1. click start>control panel
2. in classic view open the icon for network connections
3. right click on the icon for Local Area Connection and choose properties
4. in the local area connection properties window click on Internet Protocol (TCP/IP), and then click on properties
5. In the next window that opened make sure that Obtain IP address automatically and Obtain DNS address automatically both have the green button on them... click apply and then OK...
Re: No web browser
19-10-2009 6:00 PM
Re: No web browser
19-10-2009 7:28 PM
Re: No web browser
19-10-2009 10:00 PM
