No speed estimate
sparkalfa
No speed estimate
Hello I have recently had a few drops on a connection that is normally very stable. Had a 40 day connection until recently.
I went to look at the connection speed on the plusnet site and it now states no connection estimate held where perviously the estimate was 17mb. Is there a problem?
Also where on the website are the tools that show what gateway I am connected to  I scent seem to find it now
Mark
Re: No speed estimate
I've just run a line check for you so that should update soon - though you can find out the latest estimate if you pop your phone number into http://dslchecker.bt.com/
The gateway checker is at http://usertools.plus.net/@gateway
Hope that helps.
sparkalfa
Sorry still no update
My router is reporting 20meg sync speed and I am getting 16.5meg on speedtest Is this ok
Hmm, not sure why that's not updating - sorry about that. Did you try the dslchecker link as that should give you an estimate as per my previous post?
Yes, 16.5Mb on a 20Mb line sounds very much ok Smiley
Finguz
Fyi, mine hasn't had a value displayed for the last month either.
sparkalfa
Hello
Yes I did use the availability checker but it's saying 15mb I seem to be getting faster  until recently the plusnet profile matched the speeds I was seeing
