No speed estimate?
jasonfreeman
No speed estimate?
I went ont my Plusnet account then my connection settings and it says "There's no speed estimate currently held on your account."?
13 REPLIES 13
Pettitto
Fixes: 5
Re: No speed estimate?
I'm not entirely sure why there's no speed estimate showing up on your account 😕
Your Current Line Rate is showing fine though. If you'd like to find out your Speed Estimate, you can find this at http://www.dslchecker.bt.com/ .
I'll look into why that's not showing in the meantime.
jasonfreeman
ok thank you
jasonfreeman
Download estimate: 17mbps
Download range: 10-19.5
Upload speed does not have an estimate
Pettitto
Fixes: 5
That's right.
The upload speeds will be best effort.
jasonfreeman
ok thank you very much for that
jasonfreeman
was you able to find out why there was no estimate?
Pettitto
Fixes: 5
Not yet, no.
I will look into it though, I've a few other bits and bobs I need to get caught up on before doing that though I'm afraid.
jasonfreeman
Thats alright, will you be able to do it before you finish today?
Pettitto
Fixes: 5
It's not affecting the service, it's not on my high priority list I'm afraid.
As I've mentioned before, if you'd like to keep an eye on your speed estimate, it's best to look at the BT Availability Checker in the first instance.
jasonfreeman
ok thanks anyway
Pettitto
Fixes: 5
That should be displaying for you now.
steveuk
The speed estimate not showing seems to be a common problem, When i first signed up for fibre the page did originaly show an estimate but after a week or two it no longer showed up and has been the same since.
It's not a problem for me so no need to do anything on my account, I was just adding more info on what i have noticed.
jasonfreeman
I'ts showing now, thanks Chris
