No speed estimate
- Re: No speed estimate
No speed estimate
01-11-2013 2:32 PM
Hello I have recently had a few drops on a connection that is normally very stable. Had a 40 day connection until recently.
I went to look at the connection speed on the plusnet site and it now states no connection estimate held where perviously the estimate was 17mb. Is there a problem?
Also where on the website are the tools that show what gateway I am connected to I scent seem to find it now
Mark
Mark
Message 1 of 6
(1,114 Views)
5 REPLIES 5
01-11-2013 2:44 PM
I've just run a line check for you so that should update soon - though you can find out the latest estimate if you pop your phone number into http://dslchecker.bt.com/
The gateway checker is at http://usertools.plus.net/@gateway
Hope that helps.
Hope that helps.
Message 2 of 6
(636 Views)
04-11-2013 7:17 PM
Sorry still no update
My router is reporting 20meg sync speed and I am getting 16.5meg on speedtest Is this ok
Message 3 of 6
(636 Views)
05-11-2013 10:11 AM
Hmm, not sure why that's not updating - sorry about that. Did you try the dslchecker link as that should give you an estimate as per my previous post?
Yes, 16.5Mb on a 20Mb line sounds very much ok
Message 4 of 6
(636 Views)
05-11-2013 10:22 AM
Fyi, mine hasn't had a value displayed for the last month either.
Message 5 of 6
(636 Views)
06-11-2013 2:24 PM
Hello
Yes I did use the availability checker but it's saying 15mb I seem to be getting faster until recently the plusnet profile matched the speeds I was seeing
Message 6 of 6
(636 Views)
