No spare PCI slot on PC so what is optimum USB wi-fi adaptor?
- No spare PCI slot on PC so what is optimum USB wi-...
11-11-2010 12:41 PM
I was intending to buy a PCI wireless card today for my Dell Studio 540 PC (bought Sept 2009) but having taken off the PC's side panel, it turns out that there isn't a spare PCI slot at all. The two existing slots are taken up by my sound and video cards and since I don't want to lose either of those the only option available for full wireless connectivity for my PC is a USB wifi adaptor about which I have heard mixed reviews.
After a quick look on Amazon, the one that immediately stands out is the Edimax EW-7711UAN 11n 150mbs Wireless High Gain USB Adapter. It is a standard USB connection but has the same sort of aerial as on my Thomson 585 v7 router, and it is reasonably priced too which is a bonus.
If I go down the full wireless route, the router will be downstairs in the hallway, whilst the PC will remain upstairs in the back bedroom. I'm not sure how radio signals permeate around the house but the house is of standard brick construction and we have no issues with the existing (Panasonic) landline handsets so I am hoping for the same good performance for wireless broadband.
Anyway, to cut to the chase, can anyone suggest what would be the best USB adaptor to go for or would the Edimax one be suitable?
Thanks,
Spruance
Re: No spare PCI slot on PC so what is optimum USB wi-fi adaptor?
11-11-2010 12:45 PM
11-11-2010 2:33 PM
Read the reviews on Amazon before you decide what to do.
11-11-2010 3:05 PM
Jelv's suggestion looks very interesting too but obviously a bit more expensive so that might be something to fall back on if the dongle solution doesn't work out. I'm in a 3 bedroomed detached house but it's not so vast as to put me too far away from the router. The only reason I would need 40ft of ethernet cable (as mentioned in my other thread) is to avoid potential trip hazards.
Plusnet are being very obliging with my reported fault so it would be stupid of me to dig my heels in and not try to improve the situation my end. Hence moving the router downstairs to connect to the master socket seems a reasonable thing to do. This also opens up the possibility of getting a BT accelerator faceplate fitment which should improve the connection even further. It's just a pity that Dell didn't leave space for a spare PCI card but there's not a lot I can do about that.
11-11-2010 3:09 PM
11-11-2010 3:39 PM
Now that I have raised a ticket on my speed issue, I get the impression that Plusnet are taking the matter seriously so it makes sense for me to do what I reasonably can to assist their investigations. If there is still no improvement at the end of the day then I can go back to the ethernet upstairs connection but in view of Plusnet's renewed efforts I need to at least try to connect via the test socket if that's what's needed, provided that I can still remain online throughout.
11-11-2010 3:50 PM
Quote from: Spruance there isn't a spare PCI slot at all. The two existing slots are taken up by my sound and video cards
Have another look.
IIRC that model range only has1 PCI slot, plus 2 PCI-Express slots (x1 and x16).
Your Video is PROBABLY in the x16 slot leaving the X1 free.
I've got a couple of PC's with nice X1 wireless cards in, can't recall the model exactly but can check if you do actually have that slot free.
One system runs W7-x64 (and XP) the other Vista-x64 and XP, what is yours?
Edit: One of my adapters is an HP FH971AA. Cost about £30.
The other is a TP-Link TL-WN781N and was only £12 via Amazon!
The HP has a very good aerial.
11-11-2010 4:03 PM
MY PC runs 32-bit Vista Home Premium and as far as I can see the two existing slots are fully tied up with my nVidia GT220 video card (in the top slot) and Soundblaster Audigy sound card in the bottom. In the gap between there are only outer casing blanks and nothing inside.
11-11-2010 4:16 PM
There's a good comparison picture here: http://en.wikipedia.org/wiki/Pci-e#PCI_Express_.28standard.29
11-11-2010 4:30 PM
11-11-2010 4:47 PM
http://en.wikipedia.org/wiki/File:PCI_Slots_Digon3.JPG
I just know that there aren't any spare ones.
It's too gloomy now to get a decent photo but I might have a go tomorrow to take a photo of the inside of my PC case just to prove the point!
11-11-2010 5:24 PM
11-11-2010 5:29 PM
Click on Technical Overview then System Board Components.
You will see that there are a total of 4 PCI slots.
11-11-2010 5:34 PM
Quote from: MrT You will see that there are a total of 4 PCI slots.
One PCI, one PCI-Express-x16, two PCI-Express-x1.
(funny the info I looked at earlier said just 1...)
The X-1 slots are very short in comparison.
Or have you got the model wrong?
11-11-2010 5:41 PM
