No service all day - pls help!
FIXED- Subscribe to RSS Feed
- Re: No service all day - pls help!
17-11-2022 9:12 PM
Had a text to say the problem had been resolved and to restart our router which we have done. Unfortunately though the router is giving us an orange light with the red b symbol underneath (no longer flashing, which it was earlier today).
Have text the fault number again to double check - it claims there's no longer an issue with the line but I don't know if there's anything else we can try - we *really* need our internet back asap for work! 😭 Thanks in advance!
Fixed! Go to the fix.
18-11-2022 7:33 AM
18-11-2022 8:00 AM - edited 18-11-2022 8:04 AM
that light combination on the Hub One means there is an issue with the broadband username password, has it been changed? The broadband username should be in the format yourusername@plusdsl.net
It can be checked on the Home page of the Hub http://192.168.1.254 "My Services"
To change the username and/or password navigate to Advanced Settings >Broadband. Make sure you click disconnect before attempting to change
If that doesn't work then try a factory reset of the hub by pushing a paperclip or similar in the reset hole at the back. Needs to be held in for 20 seconds or more, the power light will go green.
HTH
18-11-2022 8:16 AM
