No router from plus net,use old talk talk fibre router
- Re: No router from plus net,use old talk talk fibr...
08-07-2014 7:51 PM
I still have my old talk talk huwaei router,
ive got the connection details can anyone tell me how to set it up to work on plusnet
Re: No router from plus net,use old talk talk fibre router
08-07-2014 10:57 PM
Some Talk Talk routers are locked down so it can only be used with their services. You can alternatively connect directly to the modem as shown here: http://community.plus.net/library/broadband/fibre-help-how-to-set-up-a-pppoe-dialler-in-vistawindows... whilst your router arrives.
08-07-2014 11:09 PM
It should only be a matter of changing your username & password to you plusnets username / password
If your unsure how to do this, post which model huwaei router, you have IE: HG533
I still have a few trial routers here I could grab screen shots if required
The main settings IIRC are the same
[code= Router GUI] Connection Settings
PVC Info (VPI.VCI): 0.38
Type: PPPoA
[/code]
09-07-2014 8:19 AM
The router is a huwaei HG533 Fibre optic router. Seems like it doesnt require password or logon to connect to the network,far as it says anyway.
If you go to advanced options it takes you the huwaei router settings page instead of the talk talk overview page.
The net is still connected is it possible, the line has been transferred and the router is connected to plusnet?
I had that once with a line transfer...
Anyway the model is the hg533.I have saved the plusnet connection details in word format just in case i need them,ive configured old routers with normal broadband a few times, just curious as to whether its the same with fibre etc...just username and password?
09-07-2014 8:28 AM
Quote from: TORPC
Type: PPPoA
[/code]
I thought the fibre settings were PPPoE ?
09-07-2014 8:32 AM
09-07-2014 10:04 AM
It's likely you haven't been transferred yet then. I think Talktalk use DHCP to allocate a WAN IP which would explain why there is no userid/password required.
Quote The router is a huwaei HG533 Fibre optic router. Seems like it doesnt require password or logon to connect to the network,far as it says anyway.
On PlusNet you will need to configure the WAN connection type as PPPoE and input your username & password.
Hope that helps
09-07-2014 9:20 PM
Quote from: DomS
Quote from: TORPC
Type: PPPoA
[/code]
Oops sorry my bad
Twas copied from my ADSL connection
