No reliable internet connection since the start of December
- No reliable internet connection since the start of...
08-02-2010 8:32 AM
Posting on here as im getting no ware with a support ticket, and now not getting any responce
I have been running plusnet ADSL since april 2009 and was perfect until the start of December, now the modem doesnt appear to be able to hold a good connection
Ive tired
Filters
Modem
Test Socket
There isnt anything else using my line it comes in at the front of the house and into the modem, im confused why this has been fine for about 9 months and then unusable.
Ive been running quiet line tests etc, I have some stats maybe someone could point me in the right direction. Ive tired running routerstats but the lines currently no up enough to start reporting
Re: No reliable internet connection since the start of December
12-02-2010 2:14 PM
But my connection is still really slow, even though the modems back up at 6500 / 7200 bps
Does somthing else need resetting with BT or Plusnet ?
Your DSL Connection Rate :7808 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 135 Kbps
12-02-2010 2:33 PM
There is no point reporting or investigating broadband problems while you have a voice fault.
12-02-2010 2:43 PM
So do I need somone to ammend my "IP Profile " ?
As my speed is still low, ive read on here I might need to contact someone
12-02-2010 2:49 PM
13-02-2010 1:39 PM
Was hoping BT had found and fixed where my line joins the house was uncovered and was replaced Friday
This was the router stats after the above fix - Re crimp connnection and box up
G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 7,808
Data Transferred (Sent/Received) [kB/kB]: 0.00 / 1.00
Output Power (Up/Down) [dBm]: 12.0 / 13.5
Line Attenuation (Up/Down) [dB]: 6.0 / 11.0
SN Margin (Up/Down) [dB]: 23.0 / 15.5
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Framing (Local/Remote): 10,442 / 0
Loss of Signal (Local/Remote): 1,903 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 2,322 / 0
FEC Errors (Up/Down): 0 / 53,699
CRC Errors (Up/Down): 0 / 1,045
HEC Errors (Up/Down): 0 / 964
And the stats this morning
G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 4,192
Output Power (Up/Down) [dBm]: 12.0 / 17.5
Line Attenuation (Up/Down) [dB]: 8.5 / 12.0
SN Margin (Up/Down) [dB]: 15.0 / 29.5
Loss of Framing (Local/Remote): 93 / 0
Loss of Signal (Local/Remote): 58 / 0
Error Seconds (Local/Remote): 66 / 0
FEC Errors (Up/Down): 0 / 856
CRC Errors (Up/Down): 0 / 12
HEC Errors (Up/Down): 0 / 12
13-02-2010 1:44 PM
Quote from: mixxy BT came today and hopefully fixed the voice issue
Phone lines all noisey again this morning 😞
Noisy indeed and your ADSL really doesn't like it.
Back to your phone service provider I'm afraid (BT Retail?)
15-02-2010 1:08 PM
As HP has said if your phone line is noisy again it's a case of going back to your voice provider and re-raising the fault.
19-02-2010 3:36 PM
Still got an IP Profile of 135Kbps at the mo, so hopefully by sunday it should be backup to speed
19-02-2010 4:07 PM
22-02-2010 1:39 PM
The connection is sill so slow
22-02-2010 1:46 PM
What speed does this say https://portal.plus.net/my.html?action=data_transfer_speed ?
If its still 135 then call CSC and get them to match your PlusNet profile to the BT one OR if you're lucky , one of the Comms Team might spot this thread and do it for you.
22-02-2010 1:56 PM
MisterW is right on both counts - thanks MisterW
Your profile on our side was still set to 250kb/s so I've upped this to 6500 to match the BT one. You should get the speed increase pretty much straight away. Sorry about the delay there.
22-02-2010 2:02 PM
22-02-2010 7:33 PM
Speed Down 198.77 Kbps ( 0.2 Mbps )
Speed Up 360.86 Kbps ( 0.4 Mbps )
