No internet to PC, but broadband working
- No internet to PC, but broadband working
25-08-2012 11:03 AM
I switched my PC on this morning, but got no internet. All router lights were on, so I switched my Netbook on, and the internet works fine. Do I have a fault with my PC, or could there be something wrong with the router? The PC is less than a year old.
I've re-booted several times, and changed the network cable.
Message 1 of 7
(1,240 Views)
6 REPLIES 6
Re: No internet to PC, but broadband working
25-08-2012 11:06 AM
Are you running McAfee or Plusnet Protect
Message 2 of 7
(682 Views)
25-08-2012 11:23 AM
Hi Jim.
Yes, I'm running MacAfee supplied with the Dell PC.
Message 3 of 7
(682 Views)
25-08-2012 11:36 AM
Suggest doing a system restore to middle of last week.
Macafee caused one or two problems last week!
Message 4 of 7
(682 Views)
25-08-2012 12:01 PM
Alternatively uninstall McAfee and reinstall - this should fix it.
Message 5 of 7
(682 Views)
25-08-2012 12:06 PM
Thanks James and Jim. System Restore has resolved the problem. MacAfee grrrr!
Message 6 of 7
(682 Views)
25-08-2012 12:06 PM
Ive seen this also.
http://preview.tinyurl.com/dxezvfd
Message 7 of 7
(682 Views)
