No internet light
- No internet light
No internet light
06-12-2020 10:13 PM - edited 06-12-2020 10:16 PM
Visited http gateway for router which says dsl down wait 10 minutes however nothing is working.
Re: No internet light
07-12-2020 8:29 AM
Welcome to the forums @britanywild . Based on what you have posted above, the only option is to report a fault by phone.
Is it possible to check with neighbours that their phones/BB are working, just to rule out a local network problem?
07-12-2020 9:55 AM
I had a similar problem, without internet for over a week, spent hours phoning the 0800 number and got nowhere until they got the faults team to phone me. They changed some settings remotely a couple of times which fingers crossed has solved the problem. Several people on the 0800 number were telling me the fault was internal within my house wiring etc which was not true. Try to get in touch with the faults team would be my advice.
07-12-2020 9:59 AM
07-12-2020 10:03 AM - edited 07-12-2020 10:04 AM
07-12-2020 10:21 AM
Sorry I don't think there is a number available to the public for the faults team, you need to be referred from someone on the 0800 number when you get through to them, it's a very time consuming and frustrating process.
07-12-2020 10:26 AM
@sheikanvac Which is why I posted the number I did - that will give @britanywild the option to choose the correct option.
I agree it is frustrating trying to get through, but it is the only way to get a (slightly) faster response.
07-12-2020 10:31 AM
07-12-2020 10:33 AM - edited 07-12-2020 10:34 AM
Enjoy it - might be a while. . Hope you get through.
07-12-2020 10:34 AM
07-12-2020 10:35 AM
Sorry to hear that.
