No internet light on hub
a780
All the lights are on except for the internet, I have tried all the online fixes and nothing seems to work, any suggestions?
We switched to plusnet a month ago and have had nothing but problems ever since!
This hasn't been working for 2 days now
28 REPLIES 28
a780
Slow internet???
I have just switched over to Plusnet and the internet is painfully slow.. to the point pages are just not loading. How do I upgrade my package or is this an internet issue?
Aspiring Legend
Fixes: 195
Re: Slow internet???
Welcome to the forums, @a780 . A little more information would be helpful. Can you run through this thread:https://community.plus.net/t5/ADSL-Broadband/ADSL-Speed-faults/m-p/1270245#M297501, and report the details requested?
Aspiring Legend
Fixes: 195
Re: No internet light on hub
What were the results of the tests requested in the topic I posted on your previous topic? A reply to that one may have negated the need for this one.
a780
Hi John,
I tried everything from the last topic to fix the internet being slow but nothing improved it was still ridiculously slow. This time there is no light for the internet on the router meaning I have to still connect to mobile data
Aspiring Legend
Fixes: 195
But you didn't post the information back here, as was requested, and would have possibly given some of the more experienced users a chance to help.
As to the current problem: Try disconnecting from the internet via the router interface, wait a couple of minutes, turn the power to the router of, wait a bit again, then reverse the procedure.
a780
Sorry, I tried numerous methods from other posts so I thought there would be no fix. I have done this consistently for 2 days and still no luck
Fixes: 130
In which case, its time to revert to the basics step by step and report your findings please.
Broadband is not going to work well if the "phone" line is not working properly.
Please perform a quiet line test - dial 17070 select option 2 using a corded phone plugged into the test socket behind the face plate of the master socket. It should be silent. A noisy phone line (or no dial tone) will have a marked adverse impact on the performance of broadband.
If the line is noisy or there is no dial tone, then a PHONE LINE fault needs to be raised with your phone provider. If this is PlusNet, you can report a fault on line using the button below.  From the Q&A list, choose the one which matches the problem, 'open' the 'section' and click the trouble-shooter link.  NB: If you receive a failure message (rather than a log-in prompt) then log-in to the user portal in a different browser tab and attempt to use the trouble-shooter again.
Aspiring Legend
Fixes: 195
The link I  posted in that original thread gives a structured approach to tackling the problem, and reporting the results enables others to offer suggestions or help based on experience. The way you are working at the moment merely creates more confusion.
a780
I have done what the member of staff had suggested by checking the connection status, it says DSL down and wont let me connect. We don't have a landline as we wanted purely the broadband, I will purchase a landline to see if this fixs the problem.
Aspiring Legend
Fixes: 195
I see no staff input either here or on your other topic, and you have not mentioned it previously, nor have you mentioned 'DSL down' - which changes the direction of this discussion somewhat!
a780
There was a reply I just cannot see it now! I am not tech savvy, I have no idea what any of this means, I am just trying to follow instructions to get this sorted, thank you
Fixes: 130
For clarity you do have a land line - it would appear that you do not have a telephone hand set. Without such you cannot do the very basic ‘is there a dial tone’ test.
Regardless of that you could run the phone line fault diagnostic as per the link in my previous post.
Mav
Fixes: 507
Moderator's note(s):
Two threads by the OP merged to keep support in one place.
Forum Moderator and Customer
Fixes: 1,550
Thanks for getting in touch @a780
I'm sorry for the problems with your connection. I can see you've reported a fault with your phone online and we've passed this onto our suppliers and we've been given an estimated response time of by 15/07/20 23:59:59 for an engineer to go out and investigate further. Let us know if you're still having issues once that's fixed so we can investigate further.
