No internet for nearly 2 weeks!
- Re: No internet for nearly 2 weeks!
13-11-2010 3:29 PM
Engineer visited for the second time yesterday Fixed my line (router could now pick up a ADSL signal) as there was water damage on ther pair closest to my house.
He tested the line for five mins said its good to go and left.
When i finished work and was able to use it, the connection speed was horrible and still unusable imo.
6:23pm, Friday 12 Nov 2010
router stats:
Data rate(Kbps)
Downstream 1056Kb
Upstream 672Kb
Here is my speedtest results:
Downstream 130 kbps
Upstream 573 kbps
http://www.mybroadbandspeed.co.uk/results/60629991.png
3:00pm, Saturday 13 Nov 2010
Another update:
router stats:
Data rate(Kbps)
Downstream 1312Kb
Upstream 704Kb
NEW speedtest results:
Downstream 231 kbps
Upstream 600 kbps
Again still very poor speed in relation to router stats.
BT Speed Test:
Download speedachieved during the test was - 217 Kbps
For your connection, the acceptable range of speeds is 400-1000 Kbps.
Additional Information:
Your DSL Connection Rate :1312 Kbps(DOWN-STREAM), 704 Kbps(UP-STREAM)
IP Profile for your line is - 750 Kbps
Depsite obvoiusly having a fault still, why is my ip profile so low when the other line in the house is just under 2meg and i was informed by the engineer im ment to have been routed on the best line when trying to fix the fault.
Please can someone bump my ticket as i can't create a new fault, not sure if line is still crap or something can be done ISP end thanks.
router stats:
Data rate(Kbps)
Downstream 1056Kb
Upstream 672Kb
Downstream 130 kbps
Upstream 573 kbps
Another update:
router stats:
Data rate(Kbps)
Downstream 1312Kb
Upstream 704Kb
Downstream 231 kbps
Upstream 600 kbps
BT Speed Test:
Message 1 of 2
(601 Views)
1 REPLY 1
13-11-2010 3:40 PM
Additional info for those interested.
Type Fast Path
Status SHOWTIME
Downstream Upstream
Data rate(Kbps)
1312Kb 704Kb
Noise Margin
6 6
Output power(dBm)
125 168
Attenuation(dB)
70 31
Type Fast Path
Status SHOWTIME
Downstream Upstream
Data rate(Kbps)
1312Kb 704Kb
Noise Margin
6 6
Output power(dBm)
125 168
Attenuation(dB)
70 31
Message 2 of 2
(330 Views)
