No internet connection
Thomasmey
When i try to go on my wifi it tells me to sign in so i go through the steps but when it gets to the connect page and i type my username and password and click connect it doesnt do anything if i click the reset button it says its connected to the internet but id i try to go on any webpages ot just sends me back to the hub homepage nothing works
4 REPLIES 4
Fixes: 118
Re: No internet connection
Can you please check the basics - the speed issues link below might help.
Do you have a clear dial tone?
Can you post the router stats?
Check that the user name and password in the router internet configuration page are correct.
MatthewWheeler
Fixes: 426
Sorry to hear you're having issues.
From looking at your account this should be sorted now?
Let us know if it isn't.
 Matthew Wheeler
Thomasmey
Yes this is sorted now thank you Smiley
MatthewWheeler
Fixes: 426
Glad to hear it!
 Matthew Wheeler
