No internet connection
FIXEDTopic Options
- No internet connection
10-04-2017 7:00 AM
When i try to go on my wifi it tells me to sign in so i go through the steps but when it gets to the connect page and i type my username and password and click connect it doesnt do anything if i click the reset button it says its connected to the internet but id i try to go on any webpages ot just sends me back to the hub homepage nothing works
Fixed! Go to the fix.
Message 1 of 5
(1,215 Views)
4 REPLIES 4
Re: No internet connection
10-04-2017 10:44 AM
Can you please check the basics - the speed issues link below might help.
Do you have a clear dial tone?
Can you post the router stats?
Check that the user name and password in the router internet configuration page are correct.
Message 2 of 5
(1,181 Views)
10-04-2017 11:54 AM
Message 3 of 5
(1,165 Views)
10-04-2017 12:20 PM
Yes this is sorted now thank you
Message 4 of 5
(1,153 Views)
10-04-2017 1:00 PM
Message 5 of 5
(1,140 Views)
