No internet connection on one device - others all fine
FIXED- Subscribe to RSS Feed
- Re: No internet connection on one device - others ...
19-12-2020 10:02 AM
I have decent internet connection and wifi coverage. Loads of devices working well. But one gets no internet connectivity. It is connected to the router (Onehub) and I can manage the router from it. But it gets no interent connectivity. I am stumped! Any ideas?
Fixed! Go to the fix.
Re: No internet connection on one device - others all fine
19-12-2020 10:20 AM
Welcome to the forums, @SimonC123 . What is this unconnected device?
19-12-2020 10:55 AM
It's a samsung galaxy s9
19-12-2020 12:08 PM
Apologies for the delayed response.
I have never had an Android phone, but a remedy for this type of behaviour on Apple products is to delete the connection entirely, completely turn the phone off, wait a couple of minutes and then retry.
19-12-2020 2:29 PM
Having checked further this seems to be a systemic issue with all of my samsung devices. None of our phones or tablets can access the internet. They can all connect to the wifi and can manage the router, so it clearly isn't a wifi connection problem. Just that even when logged in to the router they get no internet. Other devices (ie not samsung) are accessing the interent with no problem.
19-12-2020 2:33 PM - edited 19-12-2020 2:34 PM
In that case, it is a Samsung problem, not a Plusnet one. You will have to contact them, and hope you get a CS rep who knows what they are talking about. Sorry I can't offer any fuhrer advice.
Out of curiosity when did you first notice this?
19-12-2020 2:43 PM
Sorry to disagree, but it's a plusnet router config problem. I have never had this problem on any wifi hotspot or other home router.
It happened as soon as I turned on the new router. Since samsung devices can connect to wifi and even run the connectivity check on the router management page, it is able to access the LAN. So the problem must surely be a routing, bridging or firewall issue within the router. You can argue that samsung should change their software to overcome plusnet's config or software problems if you like but really that's bit of a cop-out.
19-12-2020 2:55 PM
I'm not suggesting that at all, but if other devices can access the 'net and only Samsung ones can't, it still points to those devices -IMHO.
As I have asked before, have tried the 'forget network' and rebooting the suspect devices option?
19-12-2020 8:00 PM
Very little info in the router but one issue seems to be that its caching the mac addresses for a long time, so may get confused by mac randomisation but then even when that is turned off it doesn't allow Internet through to select devices.
19-12-2020 8:09 PM
A very strange situation, @SimonC123 , because if this was a router/android problem. I would have expected more complaints. Unfortunately, as I have said, I am not an Android device user, nor do I use the current Plusnet router offerings. What I will do, however, is tag a fellow customer who is more experienced in this area, because I have no furher suggestions, sorry.
@Baldrick1 - any thoughts - please.
19-12-2020 9:22 PM
A couple of things to try.
1. Factory reset the hub by pushing a paperclip or similar in the reset hole. Keep the switch closed for about 30 seconds then leave it to configure itself and reconnect.
2. Separate the 2.4 and 5 GHz bands, see. https://community.plus.net/t5/My-Router/2-4ghz-and-or-5ghz-best-practice/m-p/1351966#M840. Try each band in turn.
20-12-2020 10:49 AM
Sounds like a DNS issue to me. The fact that it's only Samsung devices with the problem suggests that they are not able to reach the Samsung server they are using to test for internet access.
There's some indication out there that moving between wifi networks can cause the problem so @Baldrick1 s suggestion of splitting the Wifi bands might help. There's also a number of posts suggesting that an incorrect time on the device can cause the issue (not sure about how that could cause the problem).
If @Baldrick1 s suggestions dont work then post back and we'll try setting a static IP and DNS on one of the devices and see if that fixes it.
BTW I have two Samsung Tab A devices which work perfectly on my PN connection. I do have the wifi split though and I don't use PlusNets DNS servers.
21-12-2020 9:47 AM
Hi All,
Many thanks for your help and suggestions. I've tried all that I could easily do with no success. (Forget network, unbind 2.4 and 5 GHz nets but not new DNS or static IP.)
Being short on patience I've changed the router to a TP-Link Archer VR1200 (thanks Amazon prime!). And bingo. Everything works and (initially) seems like fewer drop-outs.
Funnily enough on windows pc had to clear chrome's cache for it to see internet but firefox seemed to sort itself out straight away. Edge had a pause but worked it out on it's own whilst I was dealing with Chrome. Never seen that before either. Does make me wonder if there are some weird/old settings in the free plusnet router.
Thanks again for your help.
22-12-2020 8:04 PM
So a codicil...
Turns out there is a known issue with newer samsung devices not working with autoswitching between 2.4 and 5Ghz bands because the devices just keep flipping between the two bands resulting in the appearing to be no internet. If you go far enough away from the router that only one band can be detected then all is fine, which is what I was seeing when I thought it was working.
I guess you could only workaround that with the basic plusnet router by having separated SSIDs for the two bands, which loses the benefit for devices that do work with the autoswitching. Luckily my non-plusnet router lets me have guest networks and so I have set up two additional networks one for 2.4 and one for 5 with different ssids. And lo, problem solved.
