No internet connection on Windows laptops
SteveWells
Both Windows laptops in my house suddenly stopped connecting to the Internet yesterday afternoon - 16/6/18 at around 3pm. All other devices - iPhones, telly and iPad are fine.
can someone help?
1 REPLY 1
Gel
Aspiring Champion
Fixes: 27
Re: No internet connection on Windows laptops
Is this via cable or wireless connection?Huh
Try rebooting the router and see if that establishes new connectivity.
If not try this
Press windows key & "r" one together.
In pop up box, type "CMD" without the quote marks.
when black box appears
type into it: IPCONFIG /FLUSHDNS
(Press enter key).
Check if you now have internet connectivity by hovering over wireless icon in bottom right of screen;
I assume you're connected to the router OK.
