No internet - Red flashing on router
ViiiMyles
Hello,
Could you please test my line or advise on the situation?
Red/Orange flashing bar consistently on router, doesn't appear to be anything I can do to improve the issue.
There has recently been resurfacing works outside my flat but I can't really see this being related to the issue.
My plusnet account uses the same email address as this forum account if you are able to check?
4 REPLIES 4
Fixes: 1,474
Re: No internet - Red flashing on router
If you got to https://faults.plus.net on your phone it will run some initial checks for you.
ViiiMyles
Thanks, I'll give this a try first when I am home from work.
I don't use a home phone so I didn't think to test this - will pinch one from the office today!
ViiiMyles
Hello
So I have no dial tone at all so I presume a fault with the line somewhere.
I have opened a case, does anyone know how long would this usually take in order to get an engineer to investigate?
Fixes: 1,474
Usualy up to 3 days
