No intenet light
- No intenet light
No intenet light
29-03-2020 5:54 PM
My hub arrived and I followed the instructions but there is no internet light showing. I have completed the steps again but to no avail. Phone line seems fine. I cant get a reply on Twitter and the call centre seems to be closed. Any ideas?
Message 1 of 2
(270 Views)
1 REPLY 1
Re: No intenet light
29-03-2020 7:22 PM
If the wiring is fine, check your username. I made a mistake when I first connected to PN years ago. Can't recall what it actually was but something to do with the plus.net or was it plusdsl.net part seems to ring bells. Good luck.
Ever helpful.
Sure, I’d love to help you out. Now which way did you come in?
Message 2 of 2
(254 Views)
