No improvement on download speed
glloyd
Although I'm now syncing at about 11 meg I see very little improvement on download speed on the speed testers over the old ADSL 1. Is PlusNet throttling the maximum line download speeds?
It may not be helped by my profile being stuck on 8000 when it should be 9000.
39 REPLIES 39
orbrey
Re: No improvement on download speed
Hi George, I've bumped the profile up to 9000 for you, not sure why that didn't pick up. We're certainly not throttling any line speeds though.
Hope that helps,
glloyd
Thanks Matt
bijelic
Hiya,
By broadband line has been upgraded and although I am seeing higher sync speed and significantly improved upload speed, I see now difference whatsoever in download speed.
Chris
Legend
Fixes: 169
@bijelic
Let me have a look and see if there is anything I can find.
*edit*
Your account was still showing as on ADSL Max from our side, I've given it a kick and it's showing as ADSL2+ with a downstream profile of 5000 now. Hopefully that's more like what you were expecting.
bijelic
Hi Chris,
Thanks for looking into this.  Just to give you a brief brakdown of my details - router is Draytek Vigor 2820n with latest stable firmware (3.3.0 UK), SNR margin is 9 to 10 and LOOP ATT. is 44 (i guess that is Attenuation Ratio).  I am about to take a look inside BT sockets in my house to see if anything there is amiss.
bijelic
Hi Chris,
Yes, I do see the improvement now.  Upload speed over 700kb and download speed @ 4.5mb (from 370kb/3.4Mb respectively).  Considering I am relatively close to the exchange, is there a way to boost the speed a bit further?
Thanks in advance!
scootie
can you get these sets of stats from you router.
        ADSL Link
        Downstream
        Upstream
        Connection Speed
        3675 kbps
        907 kbps
        Line Attenuation
        50.0 db
        28.0 db
        Noise Margin
        12.7 db
        4.4 db
http://www.kitz.co.uk/adsl/frogstats.php
this will help you if you dont know how to get the stats
ducky
hiya,
looks like I'm switched over to the trial, althought the sync speed and dl speed didn't move:
Today 18:21  6516 kbps (815kB/s)  740 kbps (92.5kB/s)
Apr 9, 21:32  6578 kbps (822kB/s) 372 kbps (46.5kB/s)
Data Rate(Kbps)
        20596                  888
Noise margin (dB)
        6.7                  13.5
Output power (dBm)
        12.0                  0.0
Attenuation (dB)
        18.5                  8.7
I will not hide the fact that the last numbers means nothing to me.. at all Cheesy
bfawcus
It looks as though I am now sorted, but my download speed is still only 6500kbps. Upload is running at 750kbps.
DownStream Connection Speed  14717 kbps
UpStream Connection Speed      855 kbps
Checked this evening via BT site:
    Your DSL connection rate: 13084 kbps(DOWN-STREAM),  852 kbps(UP-STREAM)
    IP profile for your line is - 11000 kbps
    Actual IP throughput achieved during the test was - 6184 kbps
llessah
Hi
Looks like I've been upgraded to ADSL2+  today. My synch speed is up to 9980, with a much improved upload speed of 758, but not really much improvement in the download speed of 5880. Would you please check that my profile has been updated.
scootie
to last 3 posters.
you need to wait for your ip profiles to reflect the new sync. what does your bt profile stand athttp://www.speedtester.bt.com/
i was switched on the 8th of this month and few days later i had i ticket opened and closed on my account saying PN had set my pn profile to 21000. i only have 3mb as iam along way from exchange. i am not 100% certain but i think plusnet have started to fix new trial members pn profiles to this value permanently as the 21cn profile update systems didn't seem to work 100% and jameseh was having to do it manually alot of the times
attention is this the routers way of letting you know how long your line is. mine is 51db down  around 3.6km in line length
try this site and enter your atten it will give a gd est of what your line should be capable off.
Wink tip bookmark kitz site as its got alot of info on how broadband works. very useful site
http://www.kitz.co.uk/adsl/max_speed_calc.php
bijelic
My stats are:
--------------------------- ATU-R Info (hw: annex A, f/w: annex A) -----------
  Running Mode            :    G.DMT      State                : SHOWTIME
  DS Actual Rate          :  4224000 bps  US Actual Rate      :  864000 bps
  DS Attainable Rate      :  4416000 bps  US Attainable Rate  :  1220000 bps
  DS Path Mode            :  Interleave    US Path Mode        :  Interleave
  NE Current Attenuation  :      44 dB    Cur SNR Margin      :      13  dB
  DS actual PSD          :    19. 0 dB    US actual PSD        :    12. 6  dB
-------------------------------- ATU-C Info ---------------------------------
  Far Current Attenuation :      27 dB    Far SNR Margin      :      11  dB
Interestingly my sync speed and download speed both dropped since yesterday - just over 1Mb each!
itsme
What is the make and model of the modem you are using? Does it support ADSL2+?  As a running mode of G.DMT is for standard ADSL.
bijelic
Draytek Vigor 2820n.  Fully ADSL2+.
If not G.DMT, which Modulation I need to set it to, please?
