No improvement on download speed
- Re: No improvement on download speed
14-04-2009 11:51 AM
It may not be helped by my profile being stuck on 8000 when it should be 9000.
14-04-2009 12:53 PM
Hope that helps,
14-04-2009 12:57 PM
14-04-2009 3:25 PM
By broadband line has been upgraded and although I am seeing higher sync speed and significantly improved upload speed, I see now difference whatsoever in download speed.
14-04-2009 3:57 PM
Let me have a look and see if there is anything I can find.
*edit*
Your account was still showing as on ADSL Max from our side, I've given it a kick and it's showing as ADSL2+ with a downstream profile of 5000 now. Hopefully that's more like what you were expecting.
14-04-2009 4:02 PM
Thanks for looking into this. Just to give you a brief brakdown of my details - router is Draytek Vigor 2820n with latest stable firmware (3.3.0 UK), SNR margin is 9 to 10 and LOOP ATT. is 44 (i guess that is Attenuation Ratio). I am about to take a look inside BT sockets in my house to see if anything there is amiss.
14-04-2009 4:17 PM
Yes, I do see the improvement now. Upload speed over 700kb and download speed @ 4.5mb (from 370kb/3.4Mb respectively). Considering I am relatively close to the exchange, is there a way to boost the speed a bit further?
Thanks in advance!
14-04-2009 4:23 PM
ADSL Link
Downstream
Upstream
Connection Speed
3675 kbps
907 kbps
Line Attenuation
50.0 db
28.0 db
Noise Margin
12.7 db
4.4 db
http://www.kitz.co.uk/adsl/frogstats.php
this will help you if you dont know how to get the stats
15-04-2009 6:28 PM
looks like I'm switched over to the trial, althought the sync speed and dl speed didn't move:
Today 18:21 6516 kbps (815kB/s) 740 kbps (92.5kB/s)
Apr 9, 21:32 6578 kbps (822kB/s) 372 kbps (46.5kB/s)
Data Rate(Kbps)
20596 888
Noise margin (dB)
6.7 13.5
Output power (dBm)
12.0 0.0
Attenuation (dB)
18.5 8.7
I will not hide the fact that the last numbers means nothing to me.. at all
15-04-2009 6:41 PM
DownStream Connection Speed 14717 kbps
UpStream Connection Speed 855 kbps
Checked this evening via BT site:
Your DSL connection rate: 13084 kbps(DOWN-STREAM), 852 kbps(UP-STREAM)
IP profile for your line is - 11000 kbps
Actual IP throughput achieved during the test was - 6184 kbps
15-04-2009 10:06 PM
Looks like I've been upgraded to ADSL2+ today. My synch speed is up to 9980, with a much improved upload speed of 758, but not really much improvement in the download speed of 5880. Would you please check that my profile has been updated.
16-04-2009 1:51 AM
you need to wait for your ip profiles to reflect the new sync. what does your bt profile stand athttp://www.speedtester.bt.com/
i was switched on the 8th of this month and few days later i had i ticket opened and closed on my account saying PN had set my pn profile to 21000. i only have 3mb as iam along way from exchange. i am not 100% certain but i think plusnet have started to fix new trial members pn profiles to this value permanently as the 21cn profile update systems didn't seem to work 100% and jameseh was having to do it manually alot of the times
Quote I will not hide the fact that the last numbers means nothing to me.. at all
attention is this the routers way of letting you know how long your line is. mine is 51db down around 3.6km in line length
try this site and enter your atten it will give a gd est of what your line should be capable off.
tip bookmark kitz site as its got alot of info on how broadband works. very useful site
http://www.kitz.co.uk/adsl/max_speed_calc.php
16-04-2009 4:37 PM
--------------------------- ATU-R Info (hw: annex A, f/w: annex A) -----------
Running Mode : G.DMT State : SHOWTIME
DS Actual Rate : 4224000 bps US Actual Rate : 864000 bps
DS Attainable Rate : 4416000 bps US Attainable Rate : 1220000 bps
DS Path Mode : Interleave US Path Mode : Interleave
NE Current Attenuation : 44 dB Cur SNR Margin : 13 dB
DS actual PSD : 19. 0 dB US actual PSD : 12. 6 dB
-------------------------------- ATU-C Info ---------------------------------
Far Current Attenuation : 27 dB Far SNR Margin : 11 dB
Interestingly my sync speed and download speed both dropped since yesterday - just over 1Mb each!
16-04-2009 5:34 PM
16-04-2009 5:51 PM
If not G.DMT, which Modulation I need to set it to, please?
