No dial tone but broadband still works - how?
- No dial tone but broadband still works - how?
29-12-2011 6:00 PM
I have no dial tone on my phone service but broadband continues to work. The Openreach engineer tells me that there is a break in the cable between the house and the pavement box. I don't understand how the broadband continues to work if there is a break in the cable, or at least in one of the cores. Can anyone explain please?
Message 1 of 9
(1,659 Views)
8 REPLIES 8
Re: No dial tone but broadband still works - how?
29-12-2011 6:03 PM
don't always believe an Openreach engineer?!
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
Message 2 of 9
(587 Views)
29-12-2011 6:28 PM
Broadband can actually work, after a fashion, with only one core working properly I believe whereas voice definitely doesn't
Message 3 of 9
(587 Views)
29-12-2011 6:30 PM
Well he was correct, there are a lot of reports of broadband operating on just one wire, think the signal goes back via earth
Jim beat me to it
Jim beat me to it
Message 4 of 9
(587 Views)
29-12-2011 6:36 PM
It's RF - it jumps the gap.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
Message 5 of 9
(587 Views)
29-12-2011 7:27 PM
The replies are all correct
Broadband WILL work (though badly -at a low sync ) if only one of the two wires in the incomming pair is connected.
(ie one wire is OK and the other has a break in it)
It does depend on which wire it is though!
I know - I've had it happen to me.
Message 6 of 9
(587 Views)
29-12-2011 7:32 PM
Quote from: x47c It does depend on which wire it is though!
RF isn't polarity conscious is it?
Message 7 of 9
(587 Views)
29-12-2011 11:34 PM
Exactly the same thing happened to me, I completely lost dial tone but maintained a broadband connection at a considerably reduced speed. My problem was a bad connection. I guess this was a join between two sections of wire that had become high resistance/impedance instead of very low resistance. The broadband signal operates at high power and ADSL is designed to cope with a large impedance between the exchange and your house. The telephone signal operates at relatively low power and expects a low impedance path.
Message 8 of 9
(587 Views)
30-12-2011 12:09 AM
Thanks for the replies. Broadband download speed tests at a low 1Mbps and upload at 316kbps - until the line is repaired, I guess I should be thankful for small mercies!
Message 9 of 9
(587 Views)
