No connection - how long to resolve???
- Re: No connection - how long to resolve???
04-07-2014 9:24 PM
I have left everything as it is (not working) to allow checking but I need to use the Internet ASAP
04-07-2014 9:29 PM
nothing to stop you plugging the hh5 in, would certainly help diagnose where the issue might be. i.e. router or service.
are all the lights lit up correctly on the OpenReach modem (white box)?
04-07-2014 10:20 PM
04-07-2014 10:33 PM
have you tried the HH5?
04-07-2014 10:44 PM
05-07-2014 9:16 AM
Surprise, surprise! - the internet is now working and my first speedtest (Ethernet) was 70.68Mbps download and 17.34Mbps upload. What I was expecting and had been getting when with BT Infinity.
I maintain the Technicolor router is faulty but after waiting one week and still not be told there is a problem by PlusNet is unsatisfactory.
I propose to keep the BT HomeHub 4 connected until PlusNet supply a replacement router that works as it is supposed to do so I can get access to the internet at last.
I do not want to keep the BT router permanently as is blocks Port Forwarding to my IP Cameras which was part of my reason to change from BT in the first place. The PlusNet router (when it did work for 2 days) did allow the Port Forwarding so I want a working router please!
I hope its not too much to ask as a new customer.
05-07-2014 9:34 AM
05-07-2014 10:09 AM
Re: Port Forwarding on Home Hub 4
Options
on 09-02-2014 20h48
Use the IP address not the device name.
This page should help.
Port forwarding problems http://forumhelp.dyndns.info/networking/portforward.html
There are some CCTV example on this page.
Help with setting up routers, repeaters, Smart TVs, printers, CCTV, NAS, VOIP http://forumhelp.dyndns.info/hardware/hardware_menu.html
Taken from here https://community.bt.com/t5/Other-Broadband-Queries/Port-Forwarding-on-Home-Hub-4/td-p/909354
Found with this Google search "bt home hub 4 port forwarding"
05-07-2014 11:13 AM
Interestingly I have had a message from PN this morning to advise they are sending me a new router. Thank you.
05-07-2014 11:28 AM
05-07-2014 12:03 PM
I've no experience with BT hh but I find it incredible that they are so locked down that you cannot open ports - I accept it might be difficult, but not impossible, as that would be exceedingly unhelpful!
Just taken a look here - http://portforward.com/english/routers/port_forwarding/BT/Home_Hub_4/iMessage.htm - thus is not dissimilar to the TG approach.
On the TG routers you need to know what you are doing, but it's all available via the UI.
05-07-2014 1:07 PM
Quote from: Townman I've no experience with BT hh but I find it incredible that they are so locked down that you cannot open ports - I accept it might be difficult, but not impossible, as that would be exceedingly unhelpful!
That's one thing that really puts me off going with BT, how it's all really locked down.
