No connection after unplugged
Ndziubajlo
Router cable case unplugged from the wall, and when replugged, showed no connection.
Technicolor log in screen came up, so logged in, and hit connect in broadband connection section.
No connection, and in this section 'link status' constantly says 'retrying' IPv4 state says enabled, and IPv6 state says disabled.
Not sure what is wrong here.
2 REPLIES 2
Ndziubajlo
Re: No connection after unplugged
Also when 'check connectivity' is selected, the test results say
DSL - green tick
ATM - no ATM activity detected on your dsl line
Ppp - your connection is currently down
HarryB
Fixes: 256
Welcome to the community forums @Ndziubajlo
I'm struggling to locate your account using information from your forum account. Please could you PM Me your username.
Thanks.
 Harry Beesley
