No broadband
lucy24
No broadband
Started having problems with my connection on the 20th December, new router was sent out which helped partially for about a week or so but it still dropped out regularly. From 3rd January the connection has been unusable yet each of the three times i’ve phoned there isn’t a problem with my landline. Router is constantly showing a solid orange light for no broadband, i’ve done all the resets and changed the advanced settings from default to my plusnet account. Is there anything else i’m able to do to restore the connection because it’s getting frustrating and the advisors tell me the same things
11 REPLIES 11
Fixes: 334
Re: No broadband
Welcome to the Community, @lucy24 . Before I try to help, how technically-minded are you, so I know how to phrase my questions?
lucy24
Re: No broadband
hey thanks for replying. i’m not the best techy minded person but say for example something needs doing with the router if you’re able to give me step by step I should be alright
Fixes: 334
Re: No broadband
Thanks. First things first - check all your cables are fully seated - remove them, re-insert them, and make sure they go 'click'. If that makes no difference, we need to get a bit more 'technical'.
lucy24
Re: No broadband
all done. it’s brought back the connection temporarily but still drops out every few minutes. the same happened yesterday after speaking to the advisor before loosing connection entirely
I don’t know if it’s worth mentioning but i’ve had new neighbours move in above me who had sky installed a couple of weeks ago. along with their router they’ve had two extensions installed would this be impacting my service?
Fixes: 334
Re: No broadband
Ah - that could be part of the issue, especially if they inadvertently disturbed your external cabling. The extensions wouldn't cause the issue you are describing though. I am going to post part of my 'help script' below. See if you can follow it, as the reply's may help narrow down the problem.
If you are posting from a mobile device - tablet/phone, you may need to select the 'desktop' site to post some of the requested information.
BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS'- if it will run. This test is recommended to be performed with only one device connected.
For the Hub One -
For the Hub Two -
lucy24
Re: No broadband
I think i’ve ran the BTW performance tester. apologies if the images are slightly blurry i’ve had to run this from my ps5 since it’s the only wired connection route I have. hopefully i’ve done something correct but this is over my head
Fixes: 334
Re: No broadband
No problem with the images, @lucy24 , but there is something horribly wrong with your Hub - it is not connected - at all. Although it probably won't give us much more detail, your 'status' page is not quite the one we are looking for, rather the one in the picture below:
lucy24
Re: No broadband
Fixes: 334
Re: No broadband
Thanks. I didn't know you were on ADSL2+ - very few are these days, but nonetheless, you have a problem, which needs the attention of PN/OpenReach. I suggest you report your problem via https://www.plus.net/help/report-a-problem/ and let us know the response.
As you obviously still have a phone line (and phone?), is there any noise on the line when you run a Quiet Line Test - dial 17070, select option 2. The line should be silent, apart from the regular 'Quiet Line Test' message. Do the QLT before reporting the issue.
lucy24
Re: No broadband
I do still have a phone but it’s never used, only to test the landline wherever there might be a problem. Before now all the advisers i’ve spoken to have said there isn’t a problem with the phone line but during the quiet line test there is noise crackles, i’ll report and get an engineer out to me and let you know
Thank you ever so much for your time and help, you’ve been great!
Fixes: 334
Re: No broadband
Thanks, @lucy24 .
