No broadband
wivenhoe6
No broadband
Hey guys,
My uncle currently has no broadband although his phone line is working fine.
His plusnet username is [Removed]
He has reset his router & tried both wireless & wired connections to no avail.
Can you check things your end?
Thanks very much
Moderator's note by Mike (Mav): Personal information removed from a public forum to an area that staff can see.
Plusnet Staff
Plusnet Staff
Fixes: 159
Re: No broadband
The line is disconnecting a lot.
I'd advise making sure he's in the master socket, using no extension leads and then report a fault.
I'd advise getting this reported to us as a fault at https://faults.plus.net
 Chris Parr
 Plusnet Staff
wivenhoe6
Re: No broadband
Thanks for replying Chris.
My uncle rang PlusNet today who explained that they had been carrying out updates in the local area & that something had gone wrong as a result. They rang back five minutes later to confirm that it was all fixed. Excellent service from PlusNet!
I would imagine that the disconnections you mentioned can be explained by him resetting his router etc in the hope that it would solve the issue.
Thanks Chris & the PlusNet team for your help in this matter
Plusnet Staff
Plusnet Staff
Fixes: 115
Re: No broadband
Awesome, I'm glad to hear his fault is fixed.
I think he spoke to one of my colleagues, I'll be sure to pass on your thanks to him.
I've joined the Plusnet Help Team as of May 2017. As such, I have a new forum account. Please direct any queries to @Gandalf. Thanks
 Plusnet Support
