No broadband
Legend
Fixes: 290
Re: No broadband
Those reports are covering an issue which has been resolved for the majority, as yo can  see from the current status. When did yours start?
bassline1809
Re: No broadband
8 ish
bassline1809
Re: No broadband
May 18: Problems at Plusnet
Plusnet is having issues since 10:00 PM GMT. Are you also affected? Leave a message in the comments section!
Legend
Fixes: 290
Re: No broadband
So, it is not related to the issues which started around 0400 today, and were resolved around midday.
bassline1809
Re: No broadband
Clearly not,like I say it's a waiting game now
jwsg
Re: No broadband
The problem this morning was widespread - and like the one 4 and 8 months ago was a network issue that didnt show as flashing orange or any other indication on the router - just no or intermittent service. A flashing orange might suggest a local issue between router and cabinet - not the widespread issue mentioned in reports.
Fixes: 430
Re: No broadband
@bassline1809
I don't know if it still works, but worth a try: https://faults.plus.net
bassline1809
Re: No broadband
It kind of works until it asks for a daytime number but refuses to give you a box to add this into even though it also has a mobile number box which I put in then hit submit but says there's errors on the form 🤦‍♂️
bassline1809
Re: No broadband
Unfortunately I have to go to work today but will attempt to get an advisor through the text response when I return 😀
