No broadband since midday 1st June - can't decide if it's PlusNet or my modem
MadScientist
Can somebody at PlusNet please check the status of my ADSL connection so I determine where the fault is.
Many thanks
pwatson
Re: No broadband since midday 1st June - can't decide if it's PlusNet or my modem
There are some tests can be performed by going through the process at http://faults.plus.net ;
These give PN support the info needed to work on the problem.
MadScientist
Thanks, I've been through those.  I use a separate modem and router and as I don'y have another modem\router to test, I can't totally rule out a problem at my end.
Fixes: 205
Our testing hasn't found a issue although that's not to say there isn't one.
I would recommend trying another router if possible as if a engineer goes out and finds it to be the router a charge of £50 will apply.
 Matthew Wheeler
MadScientist
Thanks, that's extremely useful to know.
I hope to have an alternative modem\router to test tomorrow.  I'm assuming that PN will not send an engineer out without consulting me first?
Fixes: 205
Correct we won't book a engineer until your happy to do so.
 Matthew Wheeler
MadScientist
Confirmed bad modem (Vigor 120).  Thanks for your help here.
Fixes: 5
Glad it's working now.
 Tony T
