No broadband from day 1.
- No broadband from day 1.
- « Previous
- Next »
Re: No broadband from day 1.
12-01-2023 4:39 PM - edited 12-01-2023 4:40 PM
@GPears With a resolution to your problem
12-01-2023 4:55 PM
Our logs are showing a connection so it looks like the exchange problem was fixed. If you're still unable to get online then it's likely caused by the high resistance fault we're seeing and as Adam suggests, unfortunately the only way we'd be able to investigate further is through arranging an engineer visit.
Just to check though, what colour is the light on your router?
12-01-2023 5:11 PM
Ah, looks like some progress - I'm guessing the exchange issue was fixed Wednesday midday.
Am I correct in thinking that the router is now connected - and has dropped just 3 times today (for whatever reason). If so, then is there a line fault at all now? With the correct login credentials the broadband should now work shouldn't it?
12-01-2023 5:15 PM
The router would have the right credentials for a connection to show up on our side. Maybe the high resistance fault is causing speed issues or something which makes it appear like there’s no connection.
12-01-2023 6:55 PM
Yes, the broadband was fixed yesterday.
We have been using it and checking the reliability when we've been home.
12-01-2023 7:33 PM
Hurrah!
12-01-2023 7:40 PM
So long story short, cutting to the chase - this is no longer the original service not connected / not working at all issue ... it is now a service not working to expectations with an observable fault on the line ... which for the purposes of boundary testing, requires access to the subscriber's NTE5. We are not looking at the same issue, just the same user.
Personally even if the fault is completely external, I would want a full test from the network boundary point in my premises. Seen too many repairs untested at the NTE5 requiring a revisit.
13-01-2023 11:02 AM
Unfortunately, as I have explained previously, we are not currently in a position to arrange a home visit for Openreach. If it had been critical then I might have considered the two x three hour round trips to get my father to be on site. But I'm certainly not going to go to that extent to satisfy curiosity.
- « Previous
- Next »
