No broadband for hours
Gpereira
Hi, I've only been with Plusnet for a few days.
My broadband stopped working at around 3pm today, 3 hours later and no signs of improvement.
It has also seemed a bit unstable in the first few days o usage before then, trying to stream using the ethernet cable at 2mbps and struggling. Can anyone help with both issues? Thank you
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: No broadband for hours
Really sorry to hear you're having problems with your broadband. Can you please private message me your account username so I can take a look for you?
Chris Pettitt
Cloud Environments Engineer
Plusnet Staff
Plusnet Staff
Fixes: 5
Thanks for the PM with your username.
I'm just testing your line now...
Chris Pettitt
Plusnet Staff
Plusnet Staff
Fixes: 5
Are you able to connect an alternative microfilter to your router, replacing the one you have currently?
Chris Pettitt
Gpereira
Excellent that seems to have sorted it cheers.
