No broadband for 24 hours
Freccle
Anyone else in manchester been offline for last 24 hours? Ive done all the tests and raised a fault report but cant even get on to check progress. Seems odd this has happened just after I agreed to another 2 year contract. I think I'm still within the cooling off period so think I'll be cancelling Angry
Heldark
Re: No broadband for 24 hours
Been offline for 48hrs in Aberdeen area.  CS phoneline mentions many customers having this problem - router reports DSL unavailable.  Recent electrical storms maybe causing a problem?
Plusnet Staff
Plusnet Staff
Fixes: 159
@Freccle
I've just tested your line and it seems that your router is trying to connect with an incorrect username. Can you log in to your router and make sure the username and password are correct, there should be instructions in the booklet we sent you on how to do this.
@Heldark
We're showing you as online now?
 Chris Parr
 Plusnet Staff
Freccle
No im not online. Im using my.phone. I try logging into the router using my plusnet user name and password and it says the username or password youve entered is incorrect please try again
Plusnet Staff
Plusnet Staff
Fixes: 159
To log in to the router the username should be admin and the password is the serial number that starts with CP
Once you've logged in to the router that's where you enter username@plusdsl.net along with your connection password.
 Chris Parr
 Plusnet Staff
Freccle
Just done the first part but it says no broadband found
Plusnet Staff
Plusnet Staff
Fixes: 159
OK, something odd is happening here. Can you dial 17070 and make sure that the number it reads back is yours please? When you do this, if the number is correct can you follow the instructions for the quiet line test.
The line test I did showed that the router has a SKY username in it, but that shouldn't be the case with it being our router, so I just want to check the above.
 Chris Parr
 Plusnet Staff
Freccle
Dial from the landline?
Freccle
Yes its our number
Freccle
Whats the quiet line test? Remember im using my mobile phone here
Fixes: 62
Quiet line test
Call 17070 from your landline phone
Freccle
Ive Just dialled that and yes its our number thats read back. I dont know what the quiet line test is and im running out ofmobile data now
Fixes: 62
it isn't relevant in this case - when you dial 17070 there are various options one of which is the quiet line test which allows you to listen for pops, crackles, etc. which can indicate a line fault
Plusnet Staff
Plusnet Staff
Fixes: 159
OK, the testing is showing a fault on the phone side of the line. So I'm reporting that to get fixed, I'll update the ticket and SMS you shortly.
 Chris Parr
 Plusnet Staff
Freccle
Sorry didnt stay on line long enough. Tried the quiet line test and all I got was loud buzzing and a series of clicks then it went dead. Yesterday I went all through trying a different splitter different router etc etc but we dont seem to be any closer to a solution. Could it be because ive asked to change to fibre but the engineer is not due out until 21 july. We cant manage that long with no internet. Im going to take my laptop to a nearby wifi spot, see if I can at least get my emails.
