No apparent change in speeds
- Re: No apparent change in speeds
26-10-2009 10:26 AM
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 13 12 0 97 98 00:00:16
LAN 10M/100M 379 463 0 2301 995 00:01:06
WLAN 11M/54M 0 0 0 0 0 00:00:56
ADSL Link Downstream Upstream
Connection Speed 4395 kbps 439 kbps
Line Attenuation 45 db 13.5 db
Noise Margin 12 db 23 db
26-10-2009 12:11 PM
Rob
26-10-2009 12:15 PM
It'll take the DLM a few days to get used to you first. See if you see any improvement in the next few days - I'd be hopeful it would get a decent bump in the right direction given how your line behaved in the past.
26-10-2009 12:18 PM
Rob
04-11-2009 9:13 AM
I’ve been on the trial since 23rd October but still haven’t noticed any change whatsoever, other than upstream doesn’t reach the previous speed of 448. I have powered down the rooter for 5 minutes or so a couple of times and re-booted each morning. Any advice?
WAN PPPoA 128 87 0 3227 384 00:00:35
LAN 10M/100M 339 479 0 1263 1996 00:01:22
WLAN 11M/54M 0 0 0 0 0 00:01:12
Connection Speed 4414 kbps 439 kbps
Noise Margin 12 db 22 db
04-11-2009 12:09 PM
Quote from: Jameseh It'll take the DLM a few days to get used to you first.
Yeah OK...... The DLM will be Ok if it decides it likes you. If it dosnt, be prepared for a fight with it......
After a few weeks, I am back to pre ADSL2+ levels on ADSL2+!!
04-11-2009 2:40 PM
Rob
Re:No apparent change in speeds
04-11-2009 3:19 PM
If the DLM likes you more than Penfold, then it should drop the SNR if your line remains stable.
04-11-2009 3:19 PM
21cn dlm can be a right pig but is good most the time on the upstream
04-11-2009 3:26 PM
I'm not aware of any capping....is this something that +net would do automatically?
04-11-2009 4:17 PM
By default, since the official launch of ADSL2+ we cap upstream speeds because it can improve (sometimes not, sometimes barely and sometimes by a considerable margin) downstream sync speeds.
If you want it uncapping, raise a ticket and we can do this for you.
04-11-2009 4:25 PM
tbh I'm not at all fussed about upstream speed, especially if it can help downstream. Should I just keep re-booting every morning and hope for improvement? I haven't had any breaks in connection other than done by me so line in stable
Rob
04-11-2009 4:43 PM
12-11-2009 4:31 PM
Saw the post below and wondered if this 28 day period whereby an increased SNR, owing to a drop in connection, will revert to a previous level is true of ADSL+2?
Rob
If James has gone, many thanks for all the help in the past; with your attitude you just can't fail in your new job
http://community.plus.net/forum/index.php/topic,80834.0.html
12-11-2009 4:33 PM
However, the potential decrease is normally done on line errors rather than uptime.
